bottom timeing mark
Old Jan 5, 2008 | 08:34 PM
HENDEL's Avatar
HENDEL
Post bottom timeing mark
this dose not have the vacume advance like old ones
ford e-150 van 5.0 302 how can i check timeing on this type of ignition system i know it's 10" btc where should the mark be on the bottom tab
Old Jan 6, 2008 | 07:27 AM
subford's Avatar
subford
Pull out the SPOUT.
Hook timing light to #1 spark plug wire (front plug on passenger side).
Start engine (RPM does not matter, 600-1200).
Loosen hold down bolt.
Look at the pointer/mark with timing light.
Turn distributor and set at 10* BTDC.
Tighten hold down bolt.
Recheck timing mark.
Put SPOUT back again and observe computer advance of 5-20 degrees.
Shut off engine and remove light.
Old Jan 6, 2008 | 09:21 AM
HENDEL's Avatar
HENDEL
thanks that help me out alot
Old Jan 6, 2008 | 09:23 AM
HENDEL's Avatar
HENDEL
Originally Posted by subford
Pull out the SPOUT.
rdweathers
Jan 3, 2013 08:08 PM
wilson123
Jul 13, 2009 07:41 PM
ranch67
Mar 23, 2007 11:21 PM
flysure2
Nov 15, 2005 08:26 AM
heybrent
1978 - 1996 Big Bronco
Aug 16, 2002 11:12 AM
