Need Help !
Old Jan 5, 2008 | 08:28 PM
auctionfynder's Avatar
auctionfynder
Need Help !
I just bought a E350 box truck and when I was driving it home the engine would backfire or spudder when it shifted into overdrive and loses power. This problem only occurs when the truck is warm. Could this issue be a fuel pump problem? Or does anyone have any suggestion for me to check. Thank you
Old Jan 6, 2008 | 06:43 AM
LxMan1's Avatar
LxMan1
Welcome to the forum.
What year and engine does it have????
Old Jan 6, 2008 | 09:32 AM
subford's Avatar
subford
First off welcome to FTE.
I take it you are talking about your 1990 Econline so I would check the EGR valve, O2 sensor, ECT sensor and the TPS.
I think a clogged cat would do it at all times and not just when it is warm.
If all of the above items check out OK then look at the TFI module & the PIP sensor.
I would also suggest that you pull the codes and see what they tell you.
Post your codes back and we will try to help you.
To check your codes if you do not know how go to one of these links below:
This is good for the KOEO test:
http://fordfuelinjection.com/?p=13
This one is good for the KOER test:
http://www.broncodata.com/tech/codes.htm
Old Jan 6, 2008 | 08:37 PM
auctionfynder
Thanks guys for the welcome. Yes it is a 1990 econoline 350 box van. It Has the 5.8 engine with the E4OD tranny. I will check the codes and relay the info in a few days. Also will check the other suggestions. The check engine light has never come on so I hope there are some errors on the computer. I really thank you for your suggestions as it gives me a place to start.
Jodymarshall
Nov 25, 2016 01:21 PM
Fordtrucks123456789
Sep 16, 2015 09:56 AM
makattack
Nov 14, 2014 11:47 AM
fiddy dollars
1983 - 2012 Ranger & B-Series
Nov 28, 2010 09:59 AM
susang
Jun 19, 2001 08:27 AM
