460 to 400 swap
460 to 400 swap
Okay guys ive been looking at the books and there is a bellhousing for a 460 and a different one for a 400....I have the one for the 460 can I use it on the 400? I noticed too that the flywheel seems to mount further away from the motor on the 460 than the 400. Is this correct? What would i have to change to get the 400 to fit in the 460 spot (outside of the frame mounts which I have). Thanks
Ryan
Ryan
Kay thanks guys, I was told that if I went over to a zf-5 which I could get cheap...I would have had to get it machined to engage properly..Not sure what was involved and didnt really want to go through the headache. THe reason for the downgrade is shaving 100 lbs, air compressor on the 400, and the 460 has a siezed rod and piston, slammed up against the head and blew the head gasket and looks to have warped the passenger side head. THe 400 cost me $100, comes with headers, 4barrel, and air compressor. Could only find a 460 with fuel injection and that was 1000. This way is cheaper for me. Plus I plan on putting it on Propane and when I do I'll bump the compression up to around 10:1. This truck isnt going to be a speed demon, I need torque, for 4x4ing and towing. The 460 just wasnt a viable price right now. See how I like it and go from there. Might go back to it, might try a diesel swap, Hell I might swap in my 300 with the offy and 4barrel. Thanks for the info and sorry for the ramble. Oh and the flywheel is different but the clutch will swap over. At least I hope so cuz its already bolted up!
Ryan
Ryan
You may have to notch the bellhousing a tad to clear the flywheel. Atleast, that's how I remember it. As to the ZF5 speed, here's a thread I have saved for whenever I decide to do it.... https://www.ford-trucks.com/forums/4...rans-swap.html
1960fordf350
08-31-2014 01:07 PM
F350moneypit
08-18-2013 01:50 PM
401477534
16
09-10-2011 04:00 PM
motorhead_83
13
04-11-2004 12:54 AM
Thomsen
02-29-2004 08:48 PM
