Battery or Starter?
Old Jan 5, 2008 | 12:07 PM
etombo53's Avatar
etombo53
Battery or Starter?
I have a '90 F-150, 5 litre, manual trans.
Battey and cables are one week old, starter is 6 months.
Truck is used for work so there is a lot of starting. About 1/3 times I have to dump clutch to get it to start. Should I look to battery or starter for problem? Or maybe somewhere else.
Thanks for any advice.
Old Jan 5, 2008 | 12:59 PM
xltlariat87's Avatar
xltlariat87
have you checked all connections?.
Old Jan 5, 2008 | 01:37 PM
95F350XL's Avatar
95F350XL
1st id go to your parts store and have the battery tested, if thats good, then Id look into the cables. I didnt have the ground one setup right on my truck. Ford has the wierd 1 peice ground that connects to the frame and block with 1 cable. I had to make mine with 2 cables. Give them a ck and see.
Old Jan 5, 2008 | 01:58 PM
phoneman91's Avatar
phoneman91
Did you check the clutch/starter interlock switch ?? I suspect that it is going open intermittently--and only when the truck will not start. Try bypassing the switch and see if the intermittent no-start still occurs.
m.collins
36
Apr 16, 2015 11:42 AM
David LaPell
Jan 6, 2014 12:12 PM
bayslayer
Dec 5, 2011 04:26 PM
fridgeddiesel
34
Apr 7, 2011 06:12 AM
wolffee
Oct 27, 2008 05:34 PM
