2 speed rear end question
Old Jan 4, 2008 | 01:38 PM
Nojive55's Avatar
Nojive55
Is the ratio of a two speed rear end in high range higher than a stock ratio (like an overdrive) or is the low range lower for pulling? I have a stock 56 F-350 which as you know is severely limited on the top end. Would a two speed axle give me more speed. I am talking about a rear end like might have been available in the 55-59 heavy trucks.
Although I am not currently in a position to aquire, here is a likely candidate, hate to see this one junked, I've seen a lot worse resurrected.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&sspagename=STRK%3AMEBTOX%3A IT&viewitem=&item=280188381789&_trksid=p3984.cTODA Y.m238.lVI
Old Jan 4, 2008 | 06:42 PM
56f600's Avatar
56f600
I can't remember the ratio exactly of my 56 F600 2 speed rearend. I would describe it as a low range and a lower range. 5.?? and 8.?? are the ratios. Someone will be along shortly with exact numbers.
Old Jan 4, 2008 | 07:29 PM
reamer's Avatar
reamer
My High Range is 5:83. Mated with 9R-22.5" Radial tires and Solid Rims, I can get 65 mph. Screamin' though.
Old Jan 4, 2008 | 10:48 PM
HT32BSX115's Avatar
HT32BSX115
Reamer is right.
Most of them were 5.83 and 8.11:1
That rear end wouldn't work in a F3/350 though unless you could find hubs that would mate to the wheels you have.
Ring and pinions for that rear end are almost non-existent.
Cheers,
Rick
Old Jan 5, 2008 | 09:30 AM
F6Guy's Avatar
F6Guy
and unless you use 36" tall tiires your RPMS will be higher than it would be on the bigger truck.
Old Jan 5, 2008 | 02:28 PM
HT32BSX115's Avatar
HT32BSX115
My tires are about 40" diameter.
At that diameter I calculate 504 rear wheel rpm at 60mph which, at 5.83:1 is 2938 rpm.
With the 0.71 OD my E4OD has I would have 2086 rpm at 60.
Even with a 2 speed an OD is nice.
Old Jan 8, 2008 | 08:41 AM
Nojive55's Avatar
Nojive55
Thanks all, (as usual) I had not considered the different bolt pattern and taller tires of the F-600. My other hobby is cross state bicycling, guess the stock F350 gearing would be a little faster than that if I ever decide to go anywhere with it.
I do have a line on a cheap Gear Vendor OD unit, doubt if they make an adaptor for my setup though.
I bought the '56 on a whim after owning an F-100 in my 'ute, I did not realize how badly I really needed it and how much fun it was going to be.
Thanks again.
Old Jan 11, 2008 | 11:47 AM
GVJosh's Avatar
GVJosh
What tranny is in that '56? If there is no adapter you may be able to do a divorced setup, where you have a short drive shaft between the tranny and GV, then another drive shaft from GV to rear end. I've seen more than a couple like that.
Old Jan 11, 2008 | 03:37 PM
Nojive55's Avatar
Nojive55
Good idea, my 350 does have the two piece driveshaft. I'll have to eye-ball it with the GV in mind. Is a divorced setup kind of like treating it like a transfer case?
I noticed in my '56 shop manual that a 5 speed OD was available in the heavier trucks, the chance of finding one of those would be pretty remote I suppose, plus I'd get greater reduction with the GV.
Old Jan 11, 2008 | 04:13 PM
GVJosh's Avatar
GVJosh
A divorced (GV calls it a remote or RX) is basicaly the same as a married, except it mounts in a cage of sorts and replaces your carrier bearing. It will have and input and out put yoke. I've seen the RX units on everything from a 41 Packard to newer trucks. Give Gear Vendors a call and they can hammer out the details for you.
Old Jan 11, 2008 | 09:43 PM
reamer's Avatar
reamer
I just found a Watson "brownie box" OD on ebay. I can now remove the carrier bering, and place this in-line there, (cut a cut in teh driveshalf of couse)
Tenn01PSD350
280
Jan 8, 2013 01:00 AM
66F100Again
Mar 12, 2008 06:14 PM
powerstrokeddiesel
Feb 5, 2008 06:16 PM
marvelousmarvyd
Dec 14, 2007 04:43 PM
ferraridriver
Dec 11, 2007 10:54 AM
