Aftermarket GPS install?
Old Jan 3, 2008 | 06:38 PM
AF Mezkin's Avatar
AF Mezkin
Hey fellas, I hope everybody Holidays were joyous. I need your help, I want to hard wire my TOM TOM in my Expy. I want to use the power supply from the electrochromatic rear view mirror, does any body know which wire is the POWER and which is the NEG. Any info would be great.
Old Jan 3, 2008 | 08:44 PM
bridge's Avatar
bridge
Sick 'n Tired
I believe there are three or four going into the back of that thing. I think the BK/LB is the ground and the WH/LB is the switched +. Verify with a multimeter, mine is an '06.
Old Jan 5, 2008 | 08:09 PM
AF Mezkin's Avatar
AF Mezkin
Thanks for the info.
Old Jan 14, 2008 | 12:07 PM
Skoiv's Avatar
Skoiv
I just wired a new 12v receptacle under the dash on the left side against the firewall and ran my power wire down the A pillar. I mounted the Garmin in the upper left corner of the window. As soon as I turn the key on the garmin gets power. Pretty simple and you end up using all the cord vs having to deal with it on a short run to the mirror. It is a very clean install with no visible wiring.
Old Jan 15, 2008 | 07:26 PM
AF Mezkin's Avatar
AF Mezkin
Skoiv, that sounds good. What wire did you use as your ignition power wire?
Old Jan 15, 2008 | 07:37 PM
Skoiv's Avatar
Skoiv
I'm not sure. I had the stereo installer do it. Just get a test light to find one. It really works nice. I put a double 12v plug in so the radar detector is wired the same way. Everything is hidden and comes on with the key.
tom18287
6.7L Power Stroke Diesel
Jul 12, 2015 05:12 PM
Tom 'Tommeke' Thomas
33
Dec 27, 2012 04:42 AM
tjworker
Jul 20, 2011 01:05 AM
driller tom
2004 - 2008 F150
Apr 23, 2010 05:02 PM
Zio
Jan 5, 2008 07:49 PM
