Auto Trans Shift Indicator Cable
Old Jan 3, 2008 | 01:05 PM
Virto's Avatar
Virto
Anyone have a pic or detailed description of how the gear indicator cable is attached to the steering column and how I get at it on a 93?
In my 90 it was pretty simple, the column shroud came right off and it was just looped around the bottom of the column and fixed with a screw. It was pretty strong too, held the column in place after I dropped it (and forgot about that cable).
I'm doing a cluster swap this weekend and it's plenty cold and snowy out, so I'd like to take the whole thing inside with me instead of switching the gauges in the truck, although push come to shove, I suppose I could.
Any help is appreiciated.
Kelly
Old Jan 3, 2008 | 05:16 PM
Virto's Avatar
Virto
Just one bump for this one. Maybe some of the nighttimers can shed some light on this.
If not I'll just tear into it this weekend, guess I can do the whole swap in cab.
Old Jan 3, 2008 | 05:47 PM
lostin90s's Avatar
lostin90s
Hey vitro . It mounts on right of steering wheel. Remove bottom dash panel and can see it top of that panel and the colonm meet it has and adjuster there. . It is held with I small hex head screw. The take cable loop off will come out.
Pm me you phone # if want and I'll call. I'll be hear till 9 PM .Sorry I thought I gave it to you.
You can also remove 2 screws on each side of indicator (in mid cluster. ) And slip indicator out so you can remove cluster. Good luck
Sep 26, 2023 02:47 PM
Jersey devil
Dec 10, 2016 12:22 PM
Frenchy
Jun 15, 2015 01:34 PM
GamalienaireIV
Apr 27, 2015 09:30 AM
centralNH
Jun 1, 2014 05:41 PM
