Sponsored by: Real Truck
Question about post Hub assembly install
Old Jan 3, 2008 | 08:42 AM
RckyMntnKng's Avatar
RckyMntnKng
(2001 F350 Superduty 7.3L)
Bearing started grinding on the Front driver side and after jacking it up found a decent amount of play in the wheel. Truck has 195k miles. Picked up 2 new hub assemblys and changed out both front sides....
Is there anything else I should know other than the straight-forward swap which I already finished?
Do I need alignment checked or anything like that?
Old Jan 3, 2008 | 08:56 AM
Pocket's Avatar
Pocket
As long as you didn't forget to install the new yellow o-rings on each side, you should be good to go.
Old Jan 3, 2008 | 08:58 AM
RckyMntnKng
Yep I got the new yellow o-rings in there...so I should be gravy
Nick122994
Jan 13, 2014 07:24 PM
Kevin Hayes
1997 - 2003 F150
Feb 21, 2012 09:52 AM
Bigtruckdriva
Apr 24, 2005 01:51 AM
mueckster
Oct 11, 2004 10:09 PM
MR DSL
1997 - 2003 F150
13
Jun 22, 2004 10:31 PM
