Sponsored by: Real Truck
Coolant Filter Kit...worth it???
Old Jan 3, 2008 | 08:00 AM
Bulldog68's Avatar
Bulldog68
Hey everyone. As I do every morning at the office before I have to start pushing paper, I have been crusing the net checking out different upgrades for the truck. I had heard of it once before and came across it again, the coolant Filter Kit from Dfuser.com. Who all has this kit? Is it worth it? What all does it accomplish and do for the truck?
Thanks In Advance and Happy New Year!!!
Old Jan 3, 2008 | 08:28 AM
HeavyAssault's Avatar
HeavyAssault
There is trapped sand inside the block from the casting process. Many feel by filtering the coolant they will protect and increase the life of the motor, espically the water pump. I bought mine through DieselSite who made the first complete kits for these trucks. Small amount to invest for the protection of the motor. I put this mod up there with the Oil by-pass filter as a "must do" mod.
http://www.dieselsite.com/index.asp?...ROD&ProdID=324
Old Jan 3, 2008 | 08:45 AM
Izzy351's Avatar
Izzy351
I don't think the "sand" is from the casting process. It's from the SCAs in the coolant. If you switch to Rotella ELC (a non-silicate coolant) and flush your block well, there will be no further problems with "Silicate Dropout". You can read all about that here:
http://www.sancarlosradiator.com/antifreeze_coolant.htm
Here's what it looks like (and even the gold coolant has it, but the green is worse). Click the pic for a full-size look at it:
Old Jan 4, 2008 | 02:39 PM
Beerstalker's Avatar
Beerstalker
Move on down to the 6.0L forum and there is a lot of information on the dieselsite coolant filter kit, as well as some pictures of filters that guys have cut open after using them.
Old Jan 4, 2008 | 04:45 PM
Clint40's Avatar
Clint40
Well worth the money and dont forget the billet waterneck and eliminate the badly designed metal one from ford. Clean all mating surfaces VERY well if you change the waterneck and junk the spring clamp and get a good clamp on there.
Old Jan 4, 2008 | 04:49 PM
jwplunkett's Avatar
jwplunkett
Talking Coolant Filter Kit ... worth it???
I just installed the Dieselsite coolant kit last weekend - F250 Yr 2006 FX4
Easy to install -- all parts and hoses included -- took about 2 hours to complete ---- looks like its factory installed
If you do decide to purchase one highly suggest the TWO cut off values option --- again purchased thru Dieselsite so can turn off coolant ( In and Out ) replace full flow filter without wasting coolant or better yet making a mess
I agree with previous post that its worth it for piece of mind
Plus in my viewpoint any fluid that can be filtered should be --- for long life of truck
The Big Rigs have them installed --- not installed on the F250, F350 etc I believe for factory cost reduction to remain competitive on pricing + none of the manufacturers desire for our trucks to run long term --- they are in business to sell us new replacement truck and then while we own truck have failures so manufacturer can service --- its all business
Hope this helps
Have a great one all
John from Colfax NC
Old Jan 4, 2008 | 06:00 PM
Izzy351's Avatar
Izzy351
I'm tellin' ya -- switch to non-sca coolant and you won't get the "sand" anymore. But it's your truck...
EDIT: Let me add that if you're concerned about the warranty, then it's probably best to keep the original coolant style and use the filter. I just noticed most of you have at least '06s. For us "old school" 7.3s, Rotella ELC is the cat's meow...
Old Jan 4, 2008 | 07:09 PM
Jzinkiewicz's Avatar
Jzinkiewicz
Where do I get the non-sca coolant?Walmart
Old Jan 4, 2008 | 09:04 PM
riggz's Avatar
riggz
Do a search in the 6.0L forum for coolant filters. I recently changed my filter in mine and showed the amount of junk that came out.
Old Jan 4, 2008 | 09:10 PM
oltrucker's Avatar
oltrucker
the so called filters used on the big rigs arent for filtering. the element is oaded with coolant additives to keep the coolant healthy and reduse the possinility of worm-holing the cylinders.
Old Jan 4, 2008 | 10:59 PM
thedaddycat's Avatar
thedaddycat
Just to make a correction here, as it says in the name these are bypass coolant filters.
They take a portion of the coolant flow from the heater hose, run it through the filter and return it to the degas bottle. If for whatever reason you leave the filter in there long enough to plug it up, you will still have full coolant flow through the rest of the cooling system.
Old Jan 4, 2008 | 11:14 PM
aortizexcursion's Avatar
aortizexcursion
I guess one could use both the dieselsite coolant filter kit and the non SCA coolant from Rotella Izzy351 is talking about. Would this be even better?
Old Jan 4, 2008 | 11:53 PM
SpringerPop's Avatar
SpringerPop
Originally Posted by oltrucker
the so called filters used on the big rigs aren't for filtering. the element is loaded with coolant additives to keep the coolant healthy and reduce the possibility of worm-holing the cylinders.
Actually, the filters with SCA's do double-duty. There's a filter element in there as well as the SCA pellets.
The filters with SCA's are rated two ways, one by the type (chemical make-up) of the SCA required, and the other by "units" of SCA. The larger the capacity cooling system, the more units of SCA. I think a Powerstroke uses a 4-unit filter (I think that's the minimum) if you add SCAs that way.
I prefer to do it manually, as I suspect I get better control that way.
Pop
Old Jan 4, 2008 | 11:56 PM
thedaddycat
I'm fairly certain that the filters the Dieselsite system uses do not have the additives in them. IIRC, they did this deliberately though I don't recall why, perhaps because the PSD uses the Premium Gold coolant.
Old Jan 4, 2008 | 11:59 PM
SpringerPop
You are correct that DieselSite's filters are non-SCA filters. I think the kits are shipped with a Baldwin B5134.
However, not all PSDs use gold coolant. I believe Ford only started the use of the gold in 2002.
Pop
