Sponsored by: Real Truck
Coolant Filter Kit...worth it???
Old Jan 5, 2008 | 12:05 AM
Izzy351's Avatar
Izzy351
There are dealers around that carry Rotella ELC, but there is a second source of the same coolant called "Final Charge". Napa carries it in concentrate. Wal-Mart has it too, but only in 50/50. If it wasn't impossible to get all the water out after a flush, the 50/50 would be fine. Some folks have just put that in knowing they don't have exactly a 50/50 mix -- I'm a bit **** about it, so I wouldn't.
Here is a link to the Rotella site where you can read about the ELC and find a distributor:
http://www.shell.com/home/Framework?siteId=rotella-en&FC2=/rotella-en/html/iwgen/leftnavs/zzz_lhn2_0_0.html&FC3=/rotella-en/html/iwgen/products/dir_products.html
Here is a link to the Final Charge site:
http://www.finalcharge.com/
Now, Final Charge says you can convert without flushing using their converter product, but for our purposes, I think it's better to just flush your system with distilled water several times, and top off with the concentrate. BTW, you'll notice they mention the coolant filters with SCAs -- with this coolant, you replace the filter with a blank. The reason is what I already said -- so silicates to drop out and get sandy, so there's nothing to filter. You could run a bypass filter with ELC but it wouldn't really do anything, providing you did a good flush.
Old Jan 5, 2008 | 01:33 AM
blackhat620's Avatar
blackhat620
Here is a link to a recent and ongoing discussion of coolant in the 6.0
http://www.ford-trucks.com/forums/69...procedure.html
Old Jan 5, 2008 | 02:51 AM
Izzy351's Avatar
Izzy351
www.ford-trucks.com/forums/690324-coolant-flush-and-refill-procedure.html
Thanks -- I added my $0.02 there as well.
Old Jan 5, 2008 | 03:38 AM
Kep4's Avatar
Kep4
Jäger
Originally Posted by HeavyAssault
There is trapped sand inside the block from the casting process. Many feel by filtering the coolant they will protect and increase the life of the motor, especially the water pump. I bought mine through DieselSite who made the first complete kits for these trucks. Small amount to invest for the protection of the motor. I put this mod up there with the Oil by-pass filter as a "must do" mod.
www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=324
I agree and it works well on my 6.0. It will keep the engine oil cooler from clogging which causes the EGR cooler to overheat.
Old Jan 5, 2008 | 05:42 AM
jwplunkett's Avatar
jwplunkett
Good morning all
TheDaddyCat --- many thanks for catching my error / my bad -- the DieselSite Coolant filter kit is definitely a By-Pass taking a portion of total coolant flow and sending it thru filter.
I took a flashlite out to truck to double verify Part # of Filter for the Dieselsite coolant kit and the filter = Baldwin B5134
Bob R warned me in advance to NOT just select any type filter for coolant system when replacing --- be certain replace with proper filter --- so I purchase a spare filter on original order .
Thanks as always for the valuable info you all share freely with us newbees
John from Colfax NC
Old Jan 5, 2008 | 11:04 AM
SpringerPop's Avatar
SpringerPop
Your local FleetPride likely stocks Baldwin as well, if you need a local source.
Pop
Old Jan 7, 2008 | 07:58 AM
Bulldog68's Avatar
Bulldog68
Thanks for all the replies everyone. Looks like I will be adding this to the list of upgrades. Never hurts to add a little something that will make the enjoyment of driving this truck last longer.
cabloom300
Dec 29, 2013 02:57 PM
bigdf350
Aug 26, 2013 10:19 PM
Sabbath5.9
Jun 12, 2013 07:14 PM
topdrive
Apr 4, 2009 10:35 AM
