need help and advice
Old Jan 4, 2008 | 08:42 PM
subford's Avatar
subford
DIODE RESISTOR ELEMENT/CIRCUIT 531
Disconnect fluid level switch.
Connect jumper wire from Circuit 531 (DG/Y) to known chassis ground.
Observe red BRAKE light.
Red BRAKE light is OFF
REPAIR open Circuit 977 (P/W), 531 (DG/Y) or open diode/resistor element. REPEAT System Pre-Check.
Red BRAKE light is ON
LEAVE fluid level switch disconnected.
Connect jumper wire from Circuit 531 (DG/Y) to Circuit 512 (T/LG).
Turn key to START position.
Red BRAKE light turns ON when key in START position
Master Cylinder fluid level switch is defective. REFER to «Section 06-06» for fluid level switch removal and installation procedures. REPEAT System Pre-Check.
Red BRAKE light remains OFF when key in START position
Open in Circuit 512 (T/LG) or defective ignition switch. REPAIR/REPLACE and REPEAT System Pre-Check.
Old Jan 5, 2008 | 12:20 PM
woody1003's Avatar
woody1003
Smile
That was the problem I think test result is that the fluid level switch is bad. can't find the part but they told me at Napa they thought Ford was recalling this piece since it is part of the cruise system and I called ford and the service dept said this would be replaced for free via the recall I will update the results after item is replaced thanks for all the help!!
Old Jan 5, 2008 | 12:38 PM
subford's Avatar
subford
Well no this is not the switch for the cruise system, that is a pressure deactivation switch that the recall is for.
Your pressure deactivation switch is near LH front rail, below drivers floor pan.
The cruise system recall has nothing to do with the fluid level switch.
Old Jan 5, 2008 | 04:29 PM
Moore558's Avatar
Moore558
Not to steal the thread, but I just got done testing mine and the switch is defective according to the test. After calling around the only way to get a new one is by buying a new (or reman) master cylinder in my case.
Old Jan 5, 2008 | 07:09 PM
woody1003's Avatar
woody1003
that stinks---is the item replaceable I cant find it nowere, do you have to get a reman master? what is usually done when this switch is bad?
edsheridan
Aug 25, 2014 02:39 PM
zrt600guy
1983 - 2012 Ranger & B-Series
Feb 14, 2012 04:10 PM
ydaveitsu
Aug 5, 2011 12:29 PM
rmalottwtes30
18
Dec 25, 2010 05:53 PM
woody1003
Feb 1, 2008 12:01 PM
