Heater Problems
Old Jan 2, 2008 | 08:05 PM
JOHN8024's Avatar
JOHN8024
Heater Problems
Was getting ready for a camping trip (it's been several months since last one), now it appears I have heater problems. I have full tanks and the furnace come on (for about 10 minute) but doesn't heat. I have dual tanks with a turn **** to selects which tank I want to use, and an indicator float gauge. I'm thinking it's my regulator, anybody have any other ideas.
thank
john
Old Jan 2, 2008 | 10:08 PM
jwshobe's Avatar
jwshobe
Since you haven't used it in a little while you might need to purge the air out.
Old Jan 3, 2008 | 03:08 AM
JOHN8024's Avatar
JOHN8024
jwshobe,
Thanks for getting with me,however, as a newbe, I'll need some education. Will you please go through the process.
Old Jan 3, 2008 | 04:56 AM
mistakenID's Avatar
mistakenID
There is likely another gas valve by the furnace that needs turned on. It will take a while to get the air out of the line.
Have you tried lighting the stove burners?
Old Jan 3, 2008 | 05:20 AM
JOHN8024's Avatar
JOHN8024
Just Checked, The Stove Works ,so The Regulator Is Not The Issue, What Valve Are You Referring To?
Old Jan 3, 2008 | 06:14 AM
jowilker's Avatar
jowilker
John These new OPD tanks can be a real PITA. I have converted every fitting that I connect over to the old POL style because of them. The tanks will allow both to be used, and as far as I know all of the concerns are with the tank and not the fitting.
Try removing the fitting from the tank, reconnect them and turn the tank valve on slowly. Just turning the valve on fast can cause the issue that you have. My son called me one day complaining that his new grill would light but not get hot, I had him turn the tank valve off and back on slowly and it worked like it was supposed to.
John
Old Jan 3, 2008 | 07:15 AM
JOHN8024's Avatar
JOHN8024
Interesting...haven't heard of that, will try that when it warms up...13 degrees here(jax fl) with the wind factor
Old Jan 3, 2008 | 08:35 AM
jowilker's Avatar
jowilker
Let us know if it helped.
We bees in teeth chattering mode in the Tarheel too.
John
Old Jan 3, 2008 | 07:24 PM
JOHN8024's Avatar
JOHN8024
Tried removing and reinstalling the fitting still doesn't fire up...however did find out is a suburban furnace model number SF30F if that helps?
Old Jan 3, 2008 | 07:47 PM
Toyman's Avatar
Toyman
Look at the exhaust side of the furnace, there is probably a spider or bees clogging it. If that is good then you will have to look at the orifice at the gas line leading into the burner tube, could be a bug nest there also.
Toyman
Old Jan 4, 2008 | 11:48 AM
JOHN8024's Avatar
JOHN8024
Toyman,
Thanks, I'll see what I can see...If this does work then I'm going with door#3...that is saying$##!@@,go to wally world and buying a radiator heater.
I thank all of you for your response.
Old Jan 4, 2008 | 11:57 AM
stormyrider's Avatar
stormyrider
I always run the stove burners to purge out the air. Furnace should at that point lite when tried.
Also on the new style tanks there is a float operated cutoff valve that prevents overfilling. I have had a propane tank filled by that instead of weight and it was a real pain to get it to allow much gas flow for a bit.
Old Jan 4, 2008 | 02:16 PM
jowilker's Avatar
jowilker
Go back to the old POL and you can eliminate that problem.
John
Old Jan 4, 2008 | 03:53 PM
JOHN8024's Avatar
JOHN8024
Gentlemen,
Thanks again, don't know what a POL is or if I ever had one,(still a newbe)I decided to take door #3,look out wally world here I come.
Old Jan 4, 2008 | 05:18 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
How old is the trailer? If you can get to the controls circuit board, see if you have a good solid 12v....Mice and varmits love gnawing things this time of year. Check for broken wires. I see that the fan runs when you call for heat, but if the controller doesn't have that 12v to call for the gas, it shuts off. If your stove burns, you do NOT have a problem with your propane tanks or regulator!
