Sponsored by: Auxito
interior lights wont go out
Old Jan 2, 2008 | 07:05 PM
croweagle's Avatar
croweagle
my truck pulls a christine once in a while, once in a while the interior lights wont go out it seems to be the drivers door switch does any one know to deactivate . it is a 2001 f-150 supercreww
Old Jan 2, 2008 | 09:18 PM
steve(ill)'s Avatar
steve(ill)
i believe the "switch" is part of the door lock inside the door. your best bet is to spray penetrant into the latch mechanism on the door end and soak everything up good.. if it still does it, remove the door panel and get closer. you could bypass the switch once you pull the panel, but i would prefer to fix it-- spray normally works.
Sy Castro
Nov 15, 2012 11:15 AM
hoss1981
Modular V10 (6.8l)
Apr 26, 2012 09:09 AM
ZaksEx03
Mar 3, 2010 01:10 PM
demery
Apr 19, 2008 03:29 AM
