The heater core debate...
Old Jan 2, 2008 | 04:56 PM
hogdogs's Avatar
hogdogs
With a baffle exactly centered in the top can and equal size tubes it will take a good argument from a physics expert to convince me that it matters which hose goes on which tube. I ain't arguing and kept in mind which one was where but since this is at least the second engine in this truck I ain't sure if they were "correct" to begin with...
Brent
Old Jan 2, 2008 | 05:33 PM
quicklook2's Avatar
quicklook2
all i know is that the ford service manual it says to hook them up with inlet to the right one in your picture.
on the engine it is the front most hose on the six, and the lower hose on the 302 and 351.
to me it looks like that will spread the hot water over the heater core with more coverage.
i do not know how yours was but mine is connected like ford says and heats like crazy.
Old Jan 3, 2008 | 04:43 AM
EPNCSU2006's Avatar
EPNCSU2006
I don't see where it matters either, but maybe it's more of a hose layout thing under hood. From a heat exchanger heat transfer standpoint, I don't think it matters.
Oh, and before you get to replacing the core, I couldn't get one like that to fit in my 87. The four square corners of the core hit the curved top and bottom of the heater box and would not fit at all.
Old Jan 3, 2008 | 09:42 AM
mhg's Avatar
mhg
the only reason that would make any differance
is if the hoses are differant sizes
M
Old Jan 3, 2008 | 11:15 AM
subford's Avatar
subford
If the core was mounted as in the photo no it would not make any difference but if it were mounted on its side it would and if the hoses were reversed you would get very little heat out of it even though the hoses were both hot.
This called an air locked heater and you would be able to hear a burbling sound as you would be putting water in at the top and the air would be trying to go to the top all the time.
They are mounted on their sides in vans. I am not sure how all the trucks are mounted and you can not always go by the lines sticking out as they may not give a clue as to the way the heater is mounted.
They sometimes use two different size heater hoses so you will not get this air lock condition.
Old Jan 3, 2008 | 11:16 PM
NEBFRD's Avatar
NEBFRD
The heater is mounted the way it sits in the picture. I just changed mine last week. It was pud.
___________________
1990 F250 4x4 460 RC
1995 Mustang GTS 5.0
Old Jan 4, 2008 | 09:17 AM
jas88's Avatar
jas88
You know, I have had 3 trucks of this vintage and they all had or have pretty weak heaters. The air is only warm and there is not much airflow. Am I the only one with this problem? I figured it was just the way they are.
Old Jan 4, 2008 | 09:20 AM
Skandocious's Avatar
Skandocious
I'm on my 2nd Ford truck of this vintage and both of them have always blown scalding hot air. You might want to check your heater core for blockage.
Old Jan 4, 2008 | 01:40 PM
jas88's Avatar
jas88
The F150 is getting ready to eat a heater core anyway. It makes that sound of water flowing in the morning on startup and I get a whiff of anti-freeze every now and again. Just waiting for it to start dripping on the floorboard and fogging up the windshield any time now.
Old Jan 5, 2008 | 08:31 AM
hogdogs's Avatar
hogdogs
I wouldn't wait for it to rupture... The coolant will fog the windows terrible and will need quite some time before it is not a problem. For 25 bucks and a 30 minute job it is worth doing now.
BTW 8 feet of heater hose is what I need for my 300-6 if you want to replace that too.
Brent
Old Jan 5, 2008 | 09:08 AM
fellro86's Avatar
fellro86
My 86 will burn you out of the cab, but I have a new core again, two already since I got it. Be sure to get a quality core, or you will wish you had. Mine never really fogged the windshield, but it makes quite the mess on the floor... If you have factory a/c, it is an easy job. I think by the time this series was made, they may all have been easy to do. Some of the early 80's trucks were a real PITA to do...
Old Jan 5, 2008 | 10:14 PM
Old_Paint's Avatar
Old_Paint
Try an '86 T-Bird. Once I saw where it was, my decision was NO WAY!. Gotta pull the entire dash out to do the core in the bird.
Judging from that pic, I'd have to stand my ground and say I don't see how coolant flow direction would make even a hint of difference in it's efficiency, regardless of mounting orientation. Maybe if you had a bubble trapped that stopped flow in some of the tubes if it was on it's side, but the flow rate in that thing would eventually eliminate the bubbles. That's what 'burping' the core is all about anyway.
I ain't buying that which hose goes where makes a difference yet. Neither of my hoses has EVER been off my '92 to my knowledge. In fact, it's still running on ALL original factory hoses. To my knowledge, the coolant's only been changed ONCE in it's life-time. I'm the original owner as well, so I DO know the history of this truck. I went nearly 100K miles before having the coolant flushed/replaced. I was quite amazed that it was still as clean as it was. I'd NEVER had to add a drop in it's life. Gotta say, it's been an amazing truck for dependability and service.
