E-fans worth it?
Old Jan 2, 2008 | 12:41 PM
heymrdj's Avatar
heymrdj
E-fans worth it?
I've got my expy doing quite a bit of towing now (6000lb every week or a lil more) and I'm wondering if it's worth going to efans. I don't realy notice any temp problems because my towing is at relatively good speeds (55mph +) so I'm just wondering if it's worth getting rid of that horrible idle cooling and going the electric route. i'll soon be upgrading the alternator to a 200amp model to handle some more equipment, the truck will be getting a new 1100cca battery plus two deep cycles. How are efans for idle periods in the summer? I want as much cooling power as I'm getting with the clutch fan.
Old Jan 3, 2008 | 08:29 AM
c_hohensee's Avatar
c_hohensee
The biggest difference I noticed with the e-fans is in throttle response. Not having to to rotate that fan up to speed seems to have helped in that area. The adjustablilty of when they turn on is a nice feature. Living in Minnesota I havent heard them run for months with the cold weather. For me with all of the other mods I have done it was worthwhile.
Old Jan 3, 2008 | 08:47 AM
heymrdj's Avatar
heymrdj
I'm looking at the dual 16" Troyer Performance kit. At only 429$ seems like the perfect combo to go with the K&N 77 series metal cold air intake kit, and Gibson side swept single outlet cat back exhaust.
Old Jan 3, 2008 | 09:56 AM
FTE Ken's Avatar
FTE Ken
There is a group purchase going with them right now. $379. Make sure you tell them you saw them on Ford-Trucks.com to get this discount.
Old Jan 3, 2008 | 10:11 AM
heymrdj's Avatar
heymrdj
SWEEET. I gotta get these parts ordered soon .
Old Jan 3, 2008 | 09:21 PM
crackerteg's Avatar
crackerteg
Are efans worth it? Consider this, You get less parasitic loss on your crank, and therefore, have more power. Does that make it "worth it" to you?
OldWoodsDiesel
15
Sep 3, 2014 06:08 AM
bbender85
May 28, 2013 03:55 PM
70-360fe
Feb 25, 2012 07:00 PM
A/Ox4
May 10, 2011 07:25 AM
wendell borror
1983 - 2012 Ranger & B-Series
30
Aug 13, 2006 07:30 PM
