E-Fan high low setting, thermostat range
Old Feb 25, 2012 | 06:59 AM
70-360fe's Avatar
70-360fe
Got my cont. solenoid this week and going finish putting in e-fan this weekend. Just wondering what I should set the high and low temp. settings at and what range thermostat range I should got. Also taking suggestions on what brand thermostat to get and where to buy. Thanks.
Old Feb 25, 2012 | 05:31 PM
Terpfords's Avatar
Terpfords
A little experimenting is probably in order.
I like my vehicles to run a little cool for the track, but everyone has a preference. The E-fan isn't going to be completely accurate for a number of reasons, but I would think you should set the low speed in the range of the mechanical thermostat and the high speed say 10-15 degrees higher. So if you put in a 195* mechanical high speed would kick on about 210.
But you are going to have to drive it and adjust as needed.
Old Feb 25, 2012 | 06:54 PM
HIO Silver's Avatar
HIO Silver
I recommend a 180-degree fail-safe thermostat: MotoRad
As far as temp settings, 180 and 195 for a two-speed fan.
Or is yours a single-speed and you're asking the on and off temps??
Old Feb 25, 2012 | 06:58 PM
70-360fe's Avatar
70-360fe
Here are the choices I've found for thermostats, 160, 180, 192, 195. I'm thinking 180 with the low at 190 high at 205?
Old Feb 25, 2012 | 07:00 PM
70-360fe's Avatar
70-360fe
Must have posted at the same time-2 speed out of a 98 lincoln. How about this from autozone, would like to get one from local parts store if possible. Would get one off the internet if a much better product.
Failsafe/Thermostat (7200-180) | 1970 Ford F100 1/2 ton P/U 2WD 8 Cylinders Y 5.9L 2BL OHV | AutoZone.com
Found this but I would rather have fail safe protection. 180 seems to be correct for low setting, thanks. What do you think of the two?
http://performanceunlimited.com/illu...ermostats.html
yasky69
Feb 10, 2018 06:40 PM
ACEN
Jan 8, 2013 12:27 PM
cmdevildog16
Nov 7, 2011 09:11 AM
DaParm
1997 - 2003 F150
Jan 7, 2006 07:57 AM
bubbaf250
Jan 8, 2003 12:59 PM
