Help..Battery drain???
Old Jan 12, 2008 | 01:11 PM
cobra427's Avatar
cobra427
Hey fordfr4x4, is the starter cutoff on the inner fender next to the battery?.
Old Jan 13, 2008 | 04:12 PM
cowchasinsix's Avatar
cowchasinsix
Had a problem with my '89 that was similar. Turned out to be a stuck relay. Here's the discussion from when I posted.
https://www.ford-trucks.com/forums/5...ectricity.html
Old Jan 13, 2008 | 10:53 PM
ssidney's Avatar
ssidney
are there any fusable links?.....they don't get fused through fuse panel
Old Jan 23, 2008 | 10:16 AM
player300x4's Avatar
player300x4
Talking hood light
had the same problem on my 89 f150 after a week of searching found that the hood light switch was bad disconnected the switch all good now
Old Jan 23, 2008 | 11:08 AM
tfowler306's Avatar
tfowler306
Originally Posted by 95F350XL
You have to use a test light, the fluke wont read the load that is being used.
I beg to differ with you on that one. If the Fluke is used correctly it will very clearly tell you exactly how much current the system is drawing.
SAFTY NOTE::
Always use a current meeter in searies (like a test light) you must complete the circuit with the meeter...
Fluke meeters usually have a second set of red connectors for the test leads. For inital test use the 10A connection and select the current section on the meeter dial. Using a Fluke meeter will tell you lots more than a test light.
Old Jan 23, 2008 | 11:27 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
FWIW,
You might consider that the plug INTO the alternator is known to melt and cause a drain even Key Out and nothing hooked up (other than the battery)
This is pretty common and when you get a new alternator they usually give you a new pigtail plug in the box w/ it.
HTH
Old Jan 23, 2008 | 12:36 PM
cobra427's Avatar
cobra427
I'l check the alt., The fluke read .001
Old Jan 23, 2008 | 12:43 PM
95F350XL's Avatar
95F350XL
Thats right where you want it to read.
Old Jan 23, 2008 | 02:18 PM
cobra427's Avatar
cobra427
Well, the only thing I can think of is the connection to the starter?, I always thought it strange the pos. batter cable connected from the solinoid to the battery and then onto the starter?. that's the way mine is connected?.
Old Jan 23, 2008 | 02:40 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
.001 what, where? Ohms..... from the windings to ground?
Try pulling the plug from the Alt. and seeing if there's still draw @ the battery.
/Hack/
Just checked your profile.
This is a Brand New 2008 F150? Or???
If it is, why is the Q on this board?
I'm sorry if I'm adding to the confusion but I missed the vehicle in question.
Old Jan 23, 2008 | 03:14 PM
Fordfr4x4's Avatar
Fordfr4x4
Thats a good point also about the alt pigtail I just did mine after I got the third alt I had them test it, and it worked so I put it in and it didnt work, I got the new pigtail and it went right up, im guessing it went bad from me yanking on it with the other 2 alternators, you can get them at advanced auto for 7 bucks. Also what kind of stereo equipoment do you have, I actually had a remote gate on my head unit stay open a few years ago and would slowly drain my battery, I put a toggle on it till I could afford a new deck and that corrected it.
Old Jan 23, 2008 | 03:42 PM
cobra427's Avatar
cobra427
No stereo except for original radio?. I'll check the alt. tomorrow and let you guys know.
Thanks....
shaffecv
2004 - 2008 F150
Jul 28, 2013 06:58 PM
Little General
Jan 10, 2013 08:56 PM
clarkw123
Dec 3, 2010 11:22 PM
Mr.Ford 351W
Garage & Workshop
19
Aug 31, 2009 11:18 PM
RH F-350
Garage & Workshop
Dec 17, 2004 10:51 AM
