Sponsored by: Real Truck
BAttery going dead
Old Jan 8, 2013 | 05:07 PM
Little General's Avatar
Little General
BAttery going dead
I have a 2006 F350 that has a battery drain. It takes 4 or 5 days before its dead. I know the volt meter between the neg and battery post will not work, and when I tried the amp draw trick, it showed no amps. The volt meter I have is a high dollar Fluke, model # P5-600 that most all commercial electricians use. Maybe it doesn't do amps small enough to register.I know it goes up to 1000 amps but not sure how low. Any other ideas before I go to the stealer for repair?
Old Jan 8, 2013 | 05:31 PM
SC_Hoaty's Avatar
SC_Hoaty
The Fluke you have does not measure DC current according to the specs I read.
You want a meter that reads DC current in the milliamp range, since you are losing a few hundred millamps an hour to deplete the battery over 5 days.
Look at this one, or one similar that measures DC current.
RadioShack 15-Range Digital Multimeter : Multimeters | RadioShack.com
Old Jan 8, 2013 | 05:40 PM
DavidB's Avatar
DavidB
Just because you have a high dollar meter doesn't mean that it will be the best meter for your task. In any case, it should be able to read the voltage directly across the two battery terminals. Check it with the engine NOT running, and again with the engine running. Depending on the state of charge on your battery, you should read between 11.5 and about 12.5 when the engine is not running. You should read about 14.1 to 14.6 with the engine running. DO THIS FIRST. When we know those readings, then we can start looking for possible battery drain problems.
Old Jan 8, 2013 | 07:16 PM
redford's Avatar
redford
FTE Leadership Emeritus
How old is your battery?
Old Jan 8, 2013 | 07:25 PM
bubbasz1's Avatar
bubbasz1
You state that putting the tester between the neg and the battery post doesn't work. Does that mean you took the negative battery terminal off, placed a lead on the disconnected cable and one on the battery. If you have a draw this will tell you, it won't tell you the amp draw but it will let you pull fuses to see what is making the draw. Only problem with this is wilh today's cars and all the electronics you will have a draw, question is what's drawing and is it too much.
Old Jan 8, 2013 | 10:00 PM
Sand_Man's Avatar
Sand_Man
+1 on this. My wife's 08 Fusion battery recently went dead overnite and although a little time on the battery charger brought it back enough to start it, I looked and it was the original battery. It's also winter. So when she took it to the local O'Reilly for a test and they told her it tested fine, I thought not. I bought a new battery and we haven't had a bit of trouble since. Some batteries may test "good enough" but in reality any battery that's 4 or 5 years old and goes dead for no good reason is probably due for replacement.
Old Jan 10, 2013 | 08:56 PM
Little General
Taking battery to have it tested tomorrow. Bought it new in Sept. Charged it up to 100% and it should have 1035 cca . At 13 volts , my meter said 801cca and to replace. And yes I took off neg cable and today used a meter that will read DC amps. Found no drain is what pointed me towards battery.
danw64
Electrical Systems/Wiring
Nov 8, 2014 08:18 PM
ac700wildcat
Garage & Workshop
Jul 23, 2010 07:11 PM
tjcnok
Oct 1, 2008 08:10 PM
gweeds
Mar 30, 2008 08:40 AM
1993F150XL
Nov 23, 2005 05:03 PM
