460 No Go
Old Dec 8, 2002 | 05:47 PM
Taynton1's Avatar
Taynton1
460 No Go
Well I just finnished painting the truck over Thanksgiving and was planning on pulling the engine over Christmas But. On the way down the interstate (65 mph @ 4000 rpm) it started loosing power. I pulled to the side of the road and it sounded like a left side exhaust manifold donut leak. I could get it to start at a low idle. It would sputter and die if I tried to give it gas. After a $200 tow bill ( a freind no less) I have done a compression test (cold, won't run) and cylinders runs from 130 to 170 and the spread is averaged between the cylinders. I sprayed the base of the carb with starting fluid while it tried to start and that produced no change. I am running a MSD 6 on the engine. ANY SUGGESTIONS? I did say what the heck and have stated the task of pulling the engine but am a little concerned to rebuild and still have a problem.
Old Dec 8, 2002 | 08:02 PM
phantom429's Avatar
phantom429
460 No Go
Have you verified good fuel supply, healthy spark, timing chain in time, plugged exhuast. Keep on lookin, eliminate components, and you will find the problem. Keep us posted!
Nick from the frozen north
1974 F-250 4X4
soon to be 429
dana 60 front and rear
Old Dec 9, 2002 | 06:21 AM
rabidranger's Avatar
rabidranger
460 No Go
You run 4000 rpm at 65?!?! Wow. Did you spray starter fluid INTO the carb yet? That will narrow your search down a lot.
Old Dec 10, 2002 | 05:38 AM
Taynton1's Avatar
Taynton1
Post 460 No Go
I have verified fuel through carb, it is sparking because it will run at idle, but does make a noise like a exhaust manifold donut leak. How would I check for quality of spark? Are timing gear/chain problems common?
I do run 4000rpm at 65mph with the 460 to C6 to a 410 rear. I need the power to pull all those gas pumps (8 mpg empty - 6.3 with the trailer).
Old Dec 10, 2002 | 06:08 AM
rabidranger
460 No Go
Did you regap the plugs with the MSD? I think you are supposed to, that or run a hotter (or is it cooler) set.
Old Dec 10, 2002 | 07:59 AM
georgedavila's Avatar
georgedavila
460 No Go
smashclash
47
May 11, 2023 09:04 PM
fordf11948
May 2, 2017 08:43 AM
78 f150 400
Mar 10, 2017 12:06 PM
jdneal88
Aug 6, 2016 09:52 AM
Thoth88
1983 - 2012 Ranger & B-Series
Jun 1, 2016 11:27 PM
