Here are some pics of my interior project. Im gonna cover the part of my dash that goes around the radio and over the glove box soon as the vinyl shop decides to open back up. I'll do a write up after im all done. The door pannels are a PITA.
Its fabric. It is attached with spray on contact adhesive. Cliff notes version of install.
Remove headliner. Remove old fabric,leave foam. Cut Camo. Spray adhesive. Attach Camo. Reinstall.
Remove door pannels. Remove Inserts. Cut Camo. Sew Camo(wife). Spray adhesive. Attach camo. Glue inserts back on(liquid nails). Reinstall door pannels.
What is mounted on the roof and how did you mount that? Did you put a piece of metal to mount it to, because I tried mounting a scanner up top and found out later that it was all cardboard.
Mounted to the roof is a handheld scanner attached to a cb speaker. the cb speaker is attached to a piece of metal that is tucked under the front headliner trim piece.
To bring the dead back to life... did you ever finish the dash?? I absolutely love the interior... actually I would like to copy it and do it to my truck as well!! Curious to see the dash!!
