Ordered my stacks
Old Jan 1, 2008 | 03:03 PM
Storm's Avatar
Storm
Ordered my stacks
Ok Stackers.. I got my 6x36" Miter Cut Grand Rock kit ordered.. So the final comes to be... What do I do bout the water.. Do I drill a hole in the elbow or do I say forget it? What about rust.. Has anyone noticed any rust..
If the big boys with Diesels can run straight up stacks with no caps.. Then I'm sure we can lol..
Should I put a hole in the elbow, how big should it be so it don't go tick tick tick with exhaust lol
Old Jan 1, 2008 | 03:37 PM
ron's power stroke's Avatar
ron's power stroke
congrats on the stacks.. should look good on your truck..keep in mind the big truck has flex pipes where water can drain..also they run long and hard enough to blow out or evaporate the water out..
Old Jan 1, 2008 | 03:38 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Glad to hear you finally did it, i wondered when you would. Jeremy has a good idea going. On the clamp that connects the lowest point, (use an accu-seal for this) point the tightening-side of the clamp downward, and do not fully tighten it to seal. The clamp will allow just a small bit of air escape. BTW post turbo exhaust leaks don't really make a tick sound due to the fact it's not under pressure.
Old Jan 1, 2008 | 04:56 PM
Storm's Avatar
Storm
Thanks guys... I'll have flex pipe.. The Grand Rock Kit that I got has T in the bed that the stack pieces go to.. Then it goes through the bed to a 90* elbow that I connect a 12" flex pipe to link it to my exhaust underneath.
Old Jan 1, 2008 | 05:25 PM
PowerstrokeJunkie
6 liters sound awesom-er with stacks. I have one buddy with 6" miters and one with 7" miters. They sound amazing.
Old Jan 1, 2008 | 05:28 PM
SolidGround's Avatar
SolidGround
I'll agree with you there, our straight-piped 6 leaker sounds amazing (when it runs).
Doesn't sound like all hell's breaking loose like my truck !
Old Jan 1, 2008 | 05:40 PM
Storm's Avatar
Storm
So does anyone think I should drill a hole if im using flex? Last thing I want is a pipe full of water LMAO
Old Jan 1, 2008 | 05:42 PM
ron's power stroke
if you have the flex pipe and its under the truck laying flat with the truck... you should be ok..like Kris said..you can drill a 1/8 " hole too..no one will ever know..
Old Jan 1, 2008 | 05:49 PM
Storm's Avatar
Storm
Where should I drill the 1/8" hole? should it be past the flex on the bottom of the exhaust piping going to the downpipe? The way my kit is, goes 90* Elbow -> Flex Pipe -> Underbody Exhaust to Downpipe.. It's a 12" section of flex that has to be straight, not bent..
Old Jan 1, 2008 | 05:53 PM
ron's power stroke
i would find the lowest point...or make the lowest point right under the bed where water is going to puddle up and drill the hole there..the further back the better..but water willl go to the lowest point by nature,,
Old Jan 1, 2008 | 05:58 PM
Storm's Avatar
Storm
Prob the bottom of the 90* elbow facing the ground than..
Old Jan 1, 2008 | 06:04 PM
ron's power stroke
thats where i would do it..if the kit will let you make that the lowest point. (i dont have stacks..but drive a Pete with dual 7"stacks) if the kit wont let you..then you got no choice to find the lowest point and drill.. just for kicks..when you get the kit...run some water through it and see how fast water comes out the sides of the flex pipe...you may find you wont need a hole
Old Jan 1, 2008 | 06:07 PM
bandlgeorge's Avatar
bandlgeorge
Congrats on the stacks Storm!! Still have yet to do my exhaust (Straight pipe turbo back 4") Good luck on the install.
Old Jan 1, 2008 | 06:09 PM
PowerstrokeJunkie
Make the elbow the lowest point. Aim it up with the existing exhaust, then move it about 1/2" lower. Let the flex pipe make up the difference. All the water will go out there.
Old Jan 1, 2008 | 06:13 PM
Storm's Avatar
Storm
Aye I hope that freakin pipe coming off the T is long enough than for me making the elbow the lowest point..
