? about cck
Old 01-01-2008, 08:08 AM
High Intentions's Avatar
High Intentions
High Intentions is offline
Mod Specialist ;)
? about cck
Where is a good place to get the kit? How hard is it to install?Is there any pic's of install? And how much do they run?
Thank you for any info.
Old 01-01-2008, 08:39 AM
mueckster's Avatar
mueckster
mueckster is offline
http://www.dinofuelalternatives.com/...rod=DFA9903CCK This should help answer your questions.
Old 01-01-2008, 08:42 AM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
Old 01-01-2008, 12:03 PM
High Intentions
Mod Specialist ;)
Thanks for the info. mueckster did you install yours? How long did it take you?
Old 01-01-2008, 12:08 PM
bdrummonds's Avatar
bdrummonds
bdrummonds is offline
set aside 3 to 4 hours if it is the first time you have ever wrenched on your truck. If you know where all the bolts are and read the instructions in 1 sitting in the "library", then you could be done in 1.5hrs.
It is not complicated at all. just a lot of steps to follow.
Old 01-01-2008, 12:17 PM
High Intentions
Mod Specialist ;)
Thanks again you all for the info...( It's not my first time wrenching)
Old 01-01-2008, 01:42 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
One more tip: Be careful with the bolt holding the pulley bracket on. I rounded it off making the job 10x harder.
bdrummonds's Avatar
bdrummonds
Cool, then like I said it is not that bad, plus it gives you a really good chance to tighten all the things that may have worked loose under the hood, and check all your wiring harness' for visible chaffing.
BTW the torque spec for the 4 bolts that hold the PS bracket, and the 1 on the idler assembly is 36ftlbs I dont remeber it being listed in Jasons instructions.
Also go ahead and get a small tube of loctite (blue or red) for the hose to JIC fittings. The small tube that is provided by DFA with the CCkit is probably enough, but I tend to over do things, so I ran out with a couple of connections left.
deerslayer165
18
04-21-2014 06:53 PM
GTBksRule
01-28-2013 11:39 AM
vwman
10-29-2004 12:16 PM
tlitteral
04-07-2003 07:57 AM
biggame
Computer Chips & Tuners
02-07-2002 11:00 PM
Quick Reply: ? about cck
