Vacuum problem?
Old Jan 4, 2008 | 06:38 PM
HemiEater's Avatar
HemiEater
well... when it's idleing and you cup the carb with your hand.. the idle went up right??? that would indicate a lean condition..meaning it's getting to much air or not enough fuel. too much air could be from a vacuum leak, not enough fuel could be from a clogged jet or low fuel level in the bowls....got to find out which one it is. That egr gasket you made is a good place to start....
Old Jan 7, 2008 | 11:51 AM
mnjarhead's Avatar
mnjarhead
Found the problem. It was a leak on the carb gasket. I had a factory carb gasket that was about 1/16" narrower than the carb and I didn't notice it at first. That was causing it to leak. I made one that's the right size and everything seems to be all right now.
Thanks for the help.
Old Jan 7, 2008 | 11:58 AM
HemiEater's Avatar
HemiEater
That would do it.... Glad you got it running.....
xtinction
Jan 17, 2016 10:57 AM
Maggie T
Mar 24, 2013 05:41 PM
Rubenk
54
Oct 9, 2010 07:41 PM
tcbofade
53
Jun 7, 2006 02:24 PM
olthunter
Jul 24, 2001 10:00 PM
