Sponsored by: Innova
radio
Old Dec 30, 2007 | 02:23 PM
F-250beast's Avatar
F-250beast
radio
i have 97 F-250HD want to take the stock radio out but how the heck you do that different from the other ones ive took out.
Old Jan 1, 2008 | 02:12 PM
PIKE's Avatar
PIKE
If the radio is a single din,which by your description I think it is at the sides of the radio you will see two small holes.Make 2 u shaped tools out of welding wire,coat hanger might work.Push the tools into the 4 holes until you feel a little resistance and then push a little farther now a little pressure sideways away from center and pull radio out.You can also remove glove box and access radio with a extra set of hands to help push radio out.t These tools might be available from wallymart.I know every time I buy a radio from crutchfield I get a new pair.They might even have them at your local parts store,napa,orielly etc.I hope this helps.
Old Jan 1, 2008 | 05:31 PM
F-250beast's Avatar
F-250beast
thanks ill have to give that a try see if can get that to work.
Traveling4awhile
Feb 24, 2013 04:40 PM
passengerdoorsmud
Oct 4, 2012 01:21 PM
Wildcat Fan
Jan 9, 2011 10:04 PM
LeVy27
Sep 16, 2009 01:18 PM
usjosgun
Electrical Systems/Wiring
Aug 13, 2003 10:39 PM
