Climate control probs.
Old Jan 18, 2008 | 11:51 PM
dmanlyr's Avatar
dmanlyr
Nope, no need to remove eithe rupper or lower plenums. You will have to take enough of the screws out though to pry them apart a little ways as well as removing the heater core cover right behind the glove box. Take the dash pad off and glove box out to give you the room to access the screws.
David
Old Jan 19, 2008 | 07:33 AM
IcemanV8's Avatar
IcemanV8
Nice to know the dash comes off THAT easy. I didn't know it was that easy to take the dash off. Now, on the other hand, I'm also glad you don't have to take the dash off to remove the heater core, as I've replaced these before. Now my truck needs one. Has a slight leak, but barely fogs the windows up. And I hate smelling it when I turn defrost on.
But, I need to replace my parking brake light, and the right half of my gauges don't show up at night. I dunno if this is normal or not, but I like to see the oil pressure gauge, even if it is an idiot gauge.
Old Jan 19, 2008 | 09:11 AM
cfrives3's Avatar
cfrives3
You really won't believe how easy the heater core is till you do one. 30 minutes- yeah it is that easy. Everything else you mentioned is pretty simple too.
Old Feb 16, 2008 | 11:09 AM
cfrives3's Avatar
cfrives3
Ok- got the parts (both of our broncs need this door). Less than $75 total for both at the local stealership. I just came in to reread the thread to make sure I remember everything as I go. I'll see what I can do for pics.
Old Jan 15, 2010 | 08:37 PM
scottddove's Avatar
scottddove
I have brought back this tread to see if anyone could shed some more light on this issue. I am having this same issue, figured it might be the same problem. So did it fix the problem or not?? Anyone else have the same symptoms and this fix there problem? Wonder if the part is still available?
Old Jan 15, 2010 | 09:39 PM
dmanlyr's Avatar
dmanlyr
Yup, it fixes the issue. I am not sure if the parts are stil available as it has been a few years now since I have had a 80-86 vintage Ford truck.
D~
Old Jan 16, 2010 | 06:41 PM
scottddove's Avatar
scottddove
I got it fixed. It was the door for me. I just made a hinge with some zip ties and it is all fixed now. Hope this helps someone in the future.
Old Jan 17, 2010 | 12:39 AM
ctubutis's Avatar
ctubutis
I can't help myself here...
Originally Posted by scottddove
...I just made a hinge with some zip ties and it is all fixed now.
Kinda like this guy's door is all fixed?
Check out that site, it's really hilarious to see how some things get "fixed."
There, I Fixed It
Not tryin' to slam the poster or anything, this is just what clicked in my brain
when I read that....
Old Jan 17, 2010 | 12:52 PM
scottddove's Avatar
scottddove
that web site is halarious. I did have to kind of rig it but you cant see it atleast. It does work like a charm and didnt cost me nothing but some time and 2 ties.I should have took some pics I guess. I could not find the part so something had to give. And as crappy built as the part is I suspect it will last longer than the original design. Scott
Yeehaw1
1978 - 1996 Big Bronco
Oct 2, 2012 07:38 AM
cfrives3
Dec 30, 2007 01:31 PM
79 bronc
Electrical Systems/Wiring
Dec 5, 2005 02:52 PM
BigRedBronc
Computer Chips & Tuners
Aug 12, 2004 07:36 AM
Jimmy Dean
Offroad & 4x4
21
Jan 14, 2004 02:49 PM
