headlight switch issue
when i started my truck, the headlights came on, and no the autolamp switch was not on. regardless if i turned the switch to auto, off, parking lamps, or on, the lights stayed on the entire time. it was like i wasn't even turning the switch??? the lights would shut off 20 seconds after i turned off the ignition, like it was stuck in auto mode somehow. i then pulled the switch panel out and all the sudden everything worked fine. i put it back in and so far everything is good now. what gives? any ideas on this in case it happens again? thanks
