Sponsored by: Real Truck
question
Old Dec 29, 2007 | 09:49 PM
johnperdeye's Avatar
johnperdeye
question
hey guys i was riding tonight and a light on the dash came on...it looks like a gas pump with 3 little drips on the dash does anybody know what this is....thanks for the help
Old Dec 29, 2007 | 09:51 PM
boxcar1974's Avatar
boxcar1974
Guessing it is a diesel?
Water in fuel light?
Old Dec 29, 2007 | 09:59 PM
Sn00ky's Avatar
Sn00ky
it may be that they water separator is full....not really familiar w/ it myself, but i seen it in the manual....maybe someone her ecan enlighten ya
Old Dec 29, 2007 | 10:03 PM
elee3's Avatar
elee3
You need to drain the water out of the frame mounted fuel filter. It is under the drivers side of the truck on the inside of the frame basically under the drivers seat. Your owners manual covers the draining procedure.
Old Dec 29, 2007 | 10:46 PM
johnperdeye
my truck didnt have a manual in it does anybody have a procedure on how to do it
Old Dec 30, 2007 | 08:41 PM
elee3's Avatar
elee3
Go to the tech folder on the 6.0 diesel page and you will find the procedure there.
Old Dec 31, 2007 | 03:03 PM
Beerstalker's Avatar
Beerstalker
First, to download a copy of your owner's guide and deisel supplement go to this website and click on owner's guides, then click on the year, make and which guide you want.
http://www.motorcraftservice.com
Since you are new, here is a link to the 6.0L Tech Folder that elee3 mentioned.
https://www.ford-trucks.com/forums/3...ch-folder.html
And here are the directions for draining the seperator.
http://home.austin.rr.com/sbv1/Proce...ater-drain.htm
The stock drain plug has a tendency to get stripped out, many of us have upgraded to the newer style one from either Ford or International Harvester. The part numbers for it are:
IH - 2589259
Ford - 6E7Z-9C082-A
Old Dec 31, 2007 | 03:13 PM
6.0superduty's Avatar
6.0superduty
all you have to do is get the correct size allen wrench and unscrew thr small plug on the side of the frame mounted fuel fiter housing. It is the one that is on the side closest to the front driveshaft.
WXboy
1983 - 2012 Ranger & B-Series
Dec 28, 2002 09:06 PM
adigitalartist
Aug 23, 2002 09:47 PM
dash riprock
Aug 18, 2002 06:08 PM
Yeti
Apr 12, 2002 09:29 AM
lrm
Feb 25, 2002 02:43 PM
