'51Dash
Old Aug 11, 2002 | 01:14 PM
dash riprock's Avatar
dash riprock
'51Dash
Old Aug 17, 2002 | 11:31 AM
63unibody's Avatar
63unibody
'51Dash
I was wondering how to remove the gauges, switchs and trim.
Nathan
Old Aug 18, 2002 | 06:08 PM
T Bone 50 51's Avatar
T Bone 50 51
'51Dash
The cluster gauges should unbolt from inside the dash. The light switch should have a button on the switch inside the dash that you push to pull the **** out all the way . Then there should be a thin nut that you unscrew freeing the switch the key should be the same way. The others may be popped in or friction fit some may have retaing clips. hope this helps.
WXboy
1983 - 2012 Ranger & B-Series
Dec 28, 2002 09:06 PM
adigitalartist
Aug 23, 2002 09:47 PM
Yeti
Apr 12, 2002 09:29 AM
lrm
Feb 25, 2002 02:43 PM
PyroManiak
Aerostar
Jul 17, 2001 03:07 PM
