370 4v
Old Jan 14, 2003 | 11:00 PM
searching's Avatar
searching
370 4v
1987 f700 with 370 4v and an auto trans.
anyone have tune up specs (namely idle speed) on this thing? or could someone point me to someplace that might? also need a part # for the egr valve. only part of the # was on the valve. any help is much apreciated. thanks
Old Jan 15, 2003 | 12:23 AM
erikl85's Avatar
erikl85
370 4v
sorry if this does not help, but i was lead to believe that the 370 never actually existed, nor did the 385. I could be wrong somehow...
Old Jan 15, 2003 | 12:33 AM
merc460's Avatar
merc460
370 4v
Yes the 370 does exist and I can post pics to prove it
give me a day or two and I will get those specs you asked for. Eric
Old Jan 15, 2003 | 12:35 AM
erikl85's Avatar
erikl85
370 4v
>for. Eric
I fully believe you, when i first came to this forum i had read somewhere that they do not exist. They must be very rare.
Old Jan 15, 2003 | 01:10 AM
merc460's Avatar
merc460
370 4v
They are very common up here in Canada. Mostly in gas or propane powered medium series ford trucks. I have personly worked on five or six different trucks. Eric
Old Jan 15, 2003 | 07:05 AM
Just Strokin's Avatar
Just Strokin
370 4v
I would use the same tune-up specs as for a 429. You should be pretty close.
The 370 actually has a steel crank in it and a bigger front snout that some have turned down to get a steel crank for their 429's.
Old Jan 15, 2003 | 10:31 AM
erikl85's Avatar
erikl85
370 4v
Then is it the 385 that does not exist?
Old Jan 15, 2003 | 10:41 AM
Fordzzzz77's Avatar
Fordzzzz77
370 4v
370, 429 and 460 are called the 385 series engines. There is no 385 engine.
77 F250 Highboy 4X4
"The Money Pit"
"If it wasn't for Chevy's my tools would rust"
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=10344&.jpg
Old Jan 15, 2003 | 01:57 PM
460429_freak's Avatar
460429_freak
370 4v
yeah ol fordzzzz77 hit it on the button the 370 is built on the 429/460 template just it is a industrail motor just like the (don't quote me but) the 330 industrail id the same stanze of the 360/390 or was it the 391??? we have put regular 360 in these trucks don't last as long but pulled better haulling 6-8 ton just couldn't take a lot of booging down. hey to make it run better you can swap the distubutor out with a 460 (get rid of the rev limiters)but if I remember you have to have the distr. shaft and maybe the oil pump out of a 460 also get rid of the factory 4 barrel If I remeber they had goveners not the best on these motors I know a little but I am no expert.....
FORDS always look better when pulling a CHEVY
Old Jan 15, 2003 | 06:20 PM
searching's Avatar
searching
370 4v
i managed to track down the egr. but i still need to find the correct idle speed. does someone have the specs for the 429 with an auto. i hate to pay for a smog check again without knowing that my idle speed is within specs...... a little info,it failed at 748. i would guess 600 is accurate but would like to know for sure. thanks
Old Jan 15, 2003 | 09:31 PM
merc460's Avatar
merc460
370 4v
here are the tune up specs from the shop key. Eric
1986-87
spark plug type ASF32
spark plug gap .044”[1.1 mm]
Ignition timing
Federal 8* BTDC
Calif. 8* BTDC
Curb Idle [rpm]
Manual trans. 600
Auto trans. 600 [in drive]
Fast idle [rpm]
Man trans 2200
Cam step 2
Auto trans 2200
Carburetor Type Holley 4180 4-Bbl
Old Jan 15, 2003 | 11:45 PM
searching's Avatar
searching
370 4v
merc460, you rock thanks so much for the info.
Old Jan 16, 2003 | 10:09 AM
ifergusson's Avatar
ifergusson
370 4v
I just noticed that if you look at the top of this forum it lists for engines 370/385/429/460.If there isn't a 385 then maybe that should be changed.A number of years ago I bought a 1970 Mercury Cyclone at an auction for $75 only because I wanted the seats.I thought it had a 429 2 bbl. engine in it but when I took it out it had two bellhousing bolt patterns cast on the back and the c-6 bellhousing was cast at an angle so that it missed one of the top bolts.The motor was obviously from something else, but was that a 370?
Old Jan 16, 2003 | 04:31 PM
love2fixit's Avatar
love2fixit
370 4v
Old Jan 20, 2003 | 03:22 PM
fordguy76's Avatar
fordguy76
370 4v
most of the ford school buses in the 80s had 370 2v in them. says it right on the side. i was thinking of putting one in my truck if i ever came across one for cheap. the heads are different and have more low end power
