370 4v
Old Mar 15, 2008 | 09:10 PM
  #31
dixiespeed's Avatar
dixiespeed
We found out our problem...the first person who worked on the truck stuck the distribator in wrong and had it out of time.
Old Feb 1, 2011 | 05:08 AM
  #32
findmucked's Avatar
findmucked
370 Motor
The 370 Does exist, I have one in my 1983 F700. To clear things up about the "385" . There is no such beast. The numerals 385 was a series from 1978-1993 for the 370,429, and 460 medium truck motors. These replaced the FE motors of that time. All 3 motors were in the 385 series. Now the years maybe off just a bit. I also have a 1989 F800 with a 429 as well. I hope this clears a few things up.
Old Jun 26, 2011 | 10:15 AM
  #33
businmama's Avatar
businmama
first x user, just joined, need some help...havea 79 ford bluebird B600 370 2V...bought it in 1990, had it converted to N.G. dual gas. Ran it for acouple of years. It has been sitting for awhile, and I ranout of N.G.outlets here in the Kootenays. Sooo, now I am trying to get it going again on gas. Changed the plugs, they were totally carbed...then when I dumped out the oil, it was full of gas... not sure what to do no w. The engine did not run for too long, just starting and such...could I flush it with a detergent.... help...
Old Jun 26, 2011 | 10:29 AM
  #34
businmama's Avatar
businmama
hello there, was wondering if the 4v 370 isthe same engine as a 2v have a 370 2v in a ford bluebird b600.
Old Jun 26, 2011 | 12:29 PM
  #35
findmucked's Avatar
findmucked
370 4V and 2V
The 370 4V basically just means it has a 4 barrel intake with a 4 barrel carb. The 2V is a 2 barrel intake and 2 barrel carb. Both engines are identical and can use either intake.
Old Jun 26, 2011 | 10:51 PM
  #36
businmama's Avatar
businmama
ok thanks for that...
Old Jun 28, 2011 | 09:07 PM
  #37
businmama's Avatar
businmama
Originally Posted by fordguy76
most of the ford school buses in the 80s had 370 2v in them. says it right on the side. i was thinking of putting one in my truck if i ever came across one for cheap. the heads are different and have more low end power
so, fordguy76 maybe you might be able to give me some info. on my 370 2v ...firstly I found alot of gas in the oil when I last dumped it. not sure what to do about it. not sure if im allowed to reply, with a question he he
Old Dec 1, 2012 | 11:01 AM
  #38
MANSON's Avatar
MANSON
I thought the 4V was a designation for a 4 valve per cylinder head.
Old Dec 1, 2012 | 11:06 AM
  #39
MANSON's Avatar
MANSON
Old Dec 1, 2012 | 03:41 PM
  #40
85e150's Avatar
85e150
4V = 4 venturi's, or 4 barrels, as in a 4 barrel carburetor.
"Multi-valve" engines go waaaayy back, but were only relatively recently adopted in passenger cars in the US.
As multi-valve motors began to be phased in, 4 bbl (and most all other) carburetors began to be phased out.
So if you see "4v" or "2v" or "6v" or "8v" on an older motor, it's the holes in the carb, not the head.
thedieselkid
Aug 2, 2011 07:05 PM
2X53
Apr 4, 2011 09:39 AM
uniequipment
Aug 31, 2009 06:25 PM
wphill
New Member Introductions
Nov 9, 2007 08:43 PM
ford429cu
Apr 6, 2000 02:15 PM
