Sponsored by: Real Truck
severe brake pull
Old Dec 28, 2007 | 01:48 PM
taluslowend's Avatar
taluslowend
severe brake pull
I have a 2000 f 350 v10. I was experiencing some serios brake pull so I installed new front calipers, rotors, and pads. Didn't seem to help so under advice of a mechanic I replaced the rubber flex lines. Still no difference. Tires are nearing the end of thier life but have been rotated several times in my attempts to fix this brake pull issue. The thing that really boggles me is that the truck usually pulls to the left but every once in a while it desides to go to the right. I frequently tow a trailer of up to 10000 lbs. the brakes on the trailer are working great but while towing the pull gets more severe. Any suggestions on eliminating this break pull would be much appreciated.
thanks
Frank Olsen
Old Dec 28, 2007 | 02:47 PM
Frd67cobra's Avatar
Frd67cobra
Welcome to FTE taluslowend. If you would post your question in the right forum (Super Duty/ Heavy Duty) I'm sure you'll find some help.
Old Dec 28, 2007 | 05:09 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from '09 F150 forum.
Welcome to FTE and thanks for joining us in the Super Duty forum!
Old Dec 28, 2007 | 06:03 PM
oltrucker's Avatar
oltrucker
i went back and checked,,he has a f 350its a super duty, this is the sd forum, where do you think he should go.? its another case of throwing parts at a problem. the first thing i would do would be get on a gravel lot and lock up the brakes to see which one slides. did you ever touch the rotors to see if one is getting hotter than the other? could it be something in the suspension getting it go out of alignment when braking causing a pull to one side?
Old Dec 28, 2007 | 06:36 PM
blackhat620's Avatar
blackhat620
thanks
Frank Olsen
Check all front suspension and steering components. Worn ball joints, tie rod ends, steering box etc can cause the vehicle to pull under braking.
Old Dec 28, 2007 | 06:39 PM
blackhat620
Hmm read Horsepullers post above yours. OP started this thread in the 2009 F150 section of the forum originally.
Old Dec 28, 2007 | 08:21 PM
redford's Avatar
redford
I recommend taking your truck to a good mechanic for an evaluation. You may have front suspension issues, brake issues or tire issues causing your pull.
Old Dec 28, 2007 | 09:51 PM
jrtraderny's Avatar
jrtraderny
thanks
Frank Olsen
I had a 99 SD that did the same thing , went away after I did all 4 corners with new calipers and rotors. sometimes if the rear is erratic it will pull the front with it. .
jr
Jeff Olsen
25
Aug 3, 2014 07:52 PM
ericolsen01
Feb 2, 2010 02:56 AM
Snowking
52
Jun 24, 2008 08:55 AM
VaSheriff
Nov 29, 2006 09:51 AM
Mary_Kate_Olsen
1978 - 1996 Big Bronco
Jan 27, 2003 04:57 PM
