Need help in Cheyenne, WY
#31
#32
Well, I had her towed back to the house, just as yet ANOTHER wicked, windy snowstorm started blowing in!! Talk about nervous!! My baby on the back of an F650 rollback and the roads getting slick, visibility of 50 FEET, and winds in the 40+ mph range! The guy was tops and even dropped her in the driveway for me!
Now, to get her scanned & fixed....
#34
#35
#37
Originally Posted by whitesdford
Finally looked and the sensor was rotated 90 degrees, turned it back where it should be and she ran.
Just don't want someone looking at theirs thinking the solenoid is misoriented and causing a problem. Just needs to be tight and plugged in.
#38
#39
thats weird, when it was loose, if the sensor connection was straight up, it ran fine, if it rotated about 90 degrees (where i found it) it wouldnt run. It didnt move out so to say, just rotated, weird, go figure....
#40
Hmmm, maybe there is something there but there are no instructions anywhere that calls for any particular orientation. How could it? We are at the mercy of the orings on the ipr itself which could end up with the plug on the bottom. How do you overcome that? By rotating the solenoid sleeve to the top and tighten down.
I don't see how this is a problem of any kind. But then again, I am not 100% sure what is going on inside the ipr VB itself aside from a magnetic field causing the valve to either open or close.
#41
Originally Posted by zx250
Once again, this site amazes me, well, not really, I knew we have some of the finest folks in the world here.
Although I did notice to be on the list, you have to be a member of FTE.
#42
Originally Posted by papadelogan
My truck died in the parking lot at work in Cheyenne, WY. I live in Wellington, CO and fortunately have a car that I can drive to get around, but I need my truck. I'm looking/begging for any help (garage space, tow, scan tool) that anyone can offer to help me out in getting her back up & running.
Please contact me at papadelogan@gmail.com at any time. You can read more about what's going on in this thread:
https://www.ford-trucks.com/forums/6...ont-start.html
Thanks to all
Thanks to all
bigwin56f100
Ohio Chapter
06-24-2014 12:22 AM
unyalli
1999 to 2016 Super Duty
53
06-08-2014 08:52 PM
BDawg171
43
02-05-2012 07:23 PM
strokersace
01-17-2010 12:36 AM
