Durapoopie
Old Dec 27, 2007 | 11:37 PM
Talyn's Avatar
Talyn
Durapoopie
Neighbors durasmack went durapoopie.
I think its a 04-05 3/4 ton.
Has fuel in crank case.
150k'ish miles on it.
Only injectors are warrenty.
Hahaha.
Any ideas?
I think he took it in and said injectors so he woudlnt' have to pay.
This guy does not rag on his truck at all.
One of the nicer duramaxes i've seen. becides the 07 i just rode in. holy wowzers that one was nice.
What ideas you guys have?
Old Dec 28, 2007 | 08:41 PM
Talyn's Avatar
Talyn
Bump-A-Dump-A-Max.
XD!!!!!!
Old Dec 28, 2007 | 08:50 PM
1997F-350's Avatar
1997F-350
Originally Posted by Talyn
Bump-A-Dump-A-Max.
XD!!!!!!
i havent learned this motor yet like the stroke but i am sure someone at dieselplace.com can
Old Dec 28, 2007 | 09:37 PM
c00nhunterjoe's Avatar
c00nhunterjoe
the earlier duracraps had major injector issues
Old Dec 28, 2007 | 09:51 PM
frnkln2003's Avatar
frnkln2003
this is true but they susposedly fixed those problems when they came out with the newer generation of duramax in 2004.
TYLAN, let me guess his truck starts allright when it is cold but whenn it is hot it wont or has trouble starting. probably also gets a little less fuel milage than usual. this is what has happened to several of my customers trucks that have had injector problems.
when your friend takes his truck to the dealer tell him to try to work directly with the tech that works on his truck if possible. a friend of mine was able to do this and found out that he actually had a couple of injectors bad and GM was only going to let them change those injectors. long story short he argued with them and got all 8 injectors replaced even though all of them werent bad yet.
Franklin
Old Dec 29, 2007 | 02:45 PM
Talyn's Avatar
Talyn
I dont' get how bad injectors will get oil in your crank case...
Someone please Elaborate.
its tAlYn not tylan. hahaha. :P
Old Dec 29, 2007 | 04:44 PM
frnkln2003's Avatar
frnkln2003
sorry about the misspelling, bad injectors will leak. when they leak on it leaks into the oil. this generally happens by injectors just dripping fuel into the cylinder instead of spraying a mist and the unburnt fuel which cant escape seeps down through the rings into the crankcase.
Franklin
Old Dec 30, 2007 | 09:31 AM
Todd525's Avatar
Todd525
I had that problem once, but everything leaks oil to the crank case......LOL JKWY
Old Jan 3, 2008 | 11:51 AM
Talyn's Avatar
Talyn
Okay, more info I have, yes.
Its an 01 durapoopie.
They gave him an 04 duracrack for the time bein.
Said he drove to work and back took half a tank.
Stoped at work and fuel was draining out of the rear main.
Old Jan 5, 2008 | 09:09 PM
Talyn's Avatar
Talyn
One of his injectors stuck open.
168k on stock injectors. They replaced all 8.
Old Jan 5, 2008 | 09:11 PM
tjbeggs's Avatar
tjbeggs
Boy how about giving him a new engine! Diesel fuel doesn't lube main bearings very well!!!
