dp tunes
Old Dec 26, 2007 | 04:51 PM
Rick2001's Avatar
Rick2001
dp tunes
Ok. I am getting ready to order a DPtuner so I can play like the rest of you.
Th truck sees duty as an empty daily driver, and I tow a 7000lb car hauler and occasionally an 14,000 lb car hauler. I am based out of Western PA but I do make it out west ever couple of years.
So here is what I am thinking.
No Start
Stock
40 Tow
60 Tow
80 Econo
Idle 1100
Maybe
Modified Stock ( since I have a modded tranny however not planning on big oil or injectors)
80 Tow
100 Performace ( just to play?)
I kinda wish he had some more descriptions as to the differences in the tunes and what to expect and what other mods needed.
What is the differenc in the tow tunes for over 4000' elevation?
In a past e-mail to them they suggested 40 tow ( 14000lb) 60 tow (7000lb) 80 econo.
Where or how has everyone been mounting the F-5 switch? How big is the unit? Is the swither mount needed?
You can see me mods below. I am not planing on any other except for:
A turbo wastegate controller
Maybe a larger intercooler (down the road)
I'll probably get into the fuel system at some point
No injector upgrade at this point and no plans (unless the money tree blooms well)..LOL
Just let me know what you guys think.
Old Dec 26, 2007 | 05:05 PM
jhand124's Avatar
jhand124
I wish I had a pic, mine isn't attached to anything. It is right next to the steering colum on the left side. They are not very big 1"x2" very light, so it looks like it is mounted but really the cord is holding it in place where it comes through between the steering colum and the dash panel.
Old Dec 26, 2007 | 05:09 PM
That_Guy's Avatar
That_Guy
Mine is mounted the same way, the switch was alot smaller then I thought. I love mine though its worth the money
Old Dec 26, 2007 | 05:10 PM
Rick2001's Avatar
Rick2001
That sounds like it can be mounted with a little velcro.
Old Dec 26, 2007 | 05:33 PM
rbaker6336's Avatar
rbaker6336
I third that just kinda sits there
Old Dec 26, 2007 | 05:42 PM
ron's power stroke's Avatar
ron's power stroke
mine is just right of the wheel..the sp diesel exhaust brake and tc lock is just above it..looks like its ready to fall off..
i want the new switch now..it fits into a gauge pod...
Old Dec 26, 2007 | 06:09 PM
monsterbaby's Avatar
monsterbaby
Here is where mine is, just cut a hole in the dash to just barely fit the wire through then used a 1/2" square piece of velcro, never moves, easy to see and reach and looks decent IMO.
Old Dec 26, 2007 | 06:17 PM
That_Guy's Avatar
That_Guy
I like the new gauge that fits into the pod as well. I think Im goin to order the steering colum pod for mine.
Old Dec 26, 2007 | 07:07 PM
RussellF's Avatar
RussellF
That a cassette in there?.........I haven't used one of those in years.
Old Dec 26, 2007 | 07:14 PM
monsterbaby
haha yes it is CDB to be exact LOL
Old Dec 26, 2007 | 08:28 PM
Izzy351's Avatar
Izzy351
Here's mine:
Old Dec 26, 2007 | 09:09 PM
Rick2001's Avatar
Rick2001
I think I have the idea about the switch.
Any comments on the tunes I listed. Do they seem to be fitting what I describe what the truck is intended to do?
Should I get the 80 Tow also?
Old Dec 26, 2007 | 09:10 PM
95Z71's Avatar
95Z71
nice looking gauges izzy; where did you get them at? And what all do they monitor
Old Dec 27, 2007 | 01:59 AM
kupaa's Avatar
kupaa
this is how i did mine
This is where I mounted my F5 switch. It looks clean with no wires showing. I removed my dash drilled a hole just big enough to fit the F5 connector through and Epoxy the switch to the dash.
__________________
Old Dec 27, 2007 | 07:55 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Rick,
If you are not going to tow heavy loads all the time you might do away with the 40 tow and get the 140 smoke for fun. I tow in 80 econo if not very heavy.
Just a thought, good luck.
