6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
DPF part #
Old Dec 26, 2007 | 03:48 PM
jrc55's Avatar
jrc55
DPF part #
Anyone happen to know what it is? My pipes are sooty so I was going to call the parts dept before I took my truck in, just curious if they had one in stock.
Old Dec 26, 2007 | 06:52 PM
richfaa's Avatar
richfaa
Just had mine replaced last week. FRom the Invoice.
DPF 7C3Z 5H221
install kit 7C3Z 5H247
If your Tail pipe is sooty you DPf IS bad,,Yir truck will run much better with a new DPF
The invoice cost was 1037.00 not including installation cost
Old Dec 26, 2007 | 07:23 PM
jrc55's Avatar
jrc55
Thanks richfaa, exactly what I wanted to know!
Old Dec 27, 2007 | 12:11 AM
soundpro's Avatar
soundpro
DPF 7C3Z 5H221
WOW! You already have to change your DPF?
How many miles do you guys have on your trucks?
Old Dec 27, 2007 | 10:44 AM
richfaa's Avatar
richfaa
The DPF was cracked and had to be replaced.
Old Dec 27, 2007 | 12:21 PM
jrc55's Avatar
jrc55
Mine has 8k, also got a chirp from under the hood at a cold start.
Old Dec 27, 2007 | 05:48 PM
rrrmotorsports's Avatar
rrrmotorsports
DPF part#
I have 18K on my F350 DRW truck and have had new cat converters on it 2 DPF's and a new turbo. It is at Ford right now getting a new radiator DPF sensors and cracked heat shield replaced on the turbo.
Old Dec 27, 2007 | 10:55 PM
soundpro's Avatar
soundpro
Whoa. I can see it now. These DPF's are going to be a real problem. $1,000 plus labor to change it? I hope that the DPF can one day be deleted from these trucks.
Old Dec 27, 2007 | 10:56 PM
soundpro's Avatar
soundpro
Under warranty I hope?
Old Dec 28, 2007 | 08:35 AM
richfaa's Avatar
richfaa
Under warranty I hope.. Oh Yea..The truck only had 4800 miles on it.The cost with labor would no doubt be around 1300+ $.We are looking at the Ford Extended Warranty.I think the DPF is a weak link in these new motors.
dmanlyr
Large Truck
Apr 3, 2013 05:58 PM
6978sghfbjklgdfsjhkl
1978 - 1996 Big Bronco
39
Feb 13, 2013 06:25 AM
50t16t
Mar 9, 2009 08:26 AM
Dan Tenn
Feb 29, 2008 03:31 PM
johnsmart
16
Sep 22, 2003 03:48 PM
