1978 - 1996 Big Bronco
About the tailgate key switch part number
Old Dec 9, 2012 | 05:16 PM
6978sghfbjklgdfsjhkl's Avatar
I am looking for the part number for a Ford replacement rear (key) tailgate switch for my 86 Bronco. Anyone?
Old Dec 9, 2012 | 06:00 PM
Encho's Avatar
Encho
The Southernmost Mod
Sorry, no idea... you might want to try searching in a dealership, at least for the number.
Old Dec 9, 2012 | 08:47 PM
CS79bronco's Avatar
CS79bronco
From everything I have read the switch hasn't been available new for several years. Junk yard is your best bet, or online somewhere. IIRC all full-size Broncos use the same switch so year doesn't matter.
Old Dec 9, 2012 | 11:39 PM
thans for the get-back..
Thanks for the input. I was hoping for a part number so as to facilitate a NOS search for any old stock if still available. If in fact there is no old stock We can proceed of course with the usual options...salvaging from a few sources..
I have searched for options for a switch on many sites and I'm surprised that a solution for replacing the paddle switch with a new or aftermarket one doesn't exist,..yet anyway.
Maybe this has to do with most guys eliminating the tailgate altogether for off-roading?..or maybe a soft-top option?..not sure..maybe these vehicles are just too new.
Anyway..the search continues...I just don't relish the thought of searching for another 25-30 year old switch that may need work as well...after taking it out of another mud-abused 4x4 relic...
there has to be a better way...
Old Dec 9, 2012 | 11:42 PM
greystreak92's Avatar
greystreak92
There is no key switch in the tailgate. The mechanism is a regular lock cylinder with a paddle attached to the tumbler. When you rotate the key, the paddle depresses one of two button switches mounted in the assembly. One sends voltage one direction to run the window down. When the key is turned the other way, the other button is depressed and the polarity is reversed to run the window up.
Old Dec 10, 2012 | 08:34 AM
I guess I should've asked for the part number for the "KEY activated PADDLE SWITCH" in the tailgate...maybe it exists..my bad
Old Dec 10, 2012 | 11:37 AM
scott79's Avatar
scott79
if you want a Ford part number you might PM "numberdummy" he might be able to help you out. He is a great resource for Ford part numbers.
Old Dec 10, 2012 | 11:52 AM
thanks
Do you think he might entertain a PM? I may give that a try..
Thanks
Old Dec 10, 2012 | 11:57 AM
scott79's Avatar
scott79
Haha...yeah, he gets them all day long!! He is a great guy and very helpful!!
Old Dec 10, 2012 | 12:06 PM
Evidently not at this time
It seems his phone is off the hook at this time...
Old Dec 10, 2012 | 12:18 PM
scott79's Avatar
scott79
I see he hasn't been here since 12/4...maybe he is traveling or something. Just so I am clear, are you looking for the key cylinder or the internal parts to engage the up & down for the window using the key from the tailgate?
Old Dec 10, 2012 | 12:28 PM
scott79's Avatar
scott79
Here is a link for a good site with lots of info...Its like the bronco bible for me haha!! You might try to search for your answer here...?
Ford Bronco And F-150 Links - PARTS SOURCES - Including FREE BRONCO SPECIFIC PARTS CATALOGS!
Another site for ya with lots of pics and tech info for the tailgate.
http://www.supermotors.net/registry/2742/12689
Old Dec 10, 2012 | 01:27 PM
I'm looking for the actual up/down switch itself that is activated by the paddle. It has molded in wires coming from it and is part of the harness assembly. I haven't taken mine out yet. It will go up but not down. I can go up and down from the dash switch. It would seem to be a good investment in one of these micro-switch assembly's if a person were to want to use that window for a few more years and having all parts on hand to do a rebuild of the tailgate seems a good idea if it is somewhat reasonable..(which is subjective I know).
I would think this would be a sticky (replacement parts for this rear access..maybe I'm the only one who has ever wanted to find one?..I can't think so)...
Old Dec 10, 2012 | 01:32 PM
about the links
1983 Ford Bronco Tailgate Tech pictures, videos, and sounds | SuperMotors.net
thanks for the addl links. I have found and downloaded the 83bronco writeup from supermotors..very helpful...
Old Dec 10, 2012 | 02:53 PM
arctic y block's Avatar
arctic y block
I need the same switch in the gate. ND bill found me the one in the dash locally. But I have yet to ask him about the gate switch.
ND Bill (Numberdummy) is on vacation. He won't be back till around the 20th guy's.
