Carb icing
Old Aug 29, 2000 | 01:23 PM
roscoe's Avatar
roscoe
Carb icing
Recently, I installed a 300-6 in an 86 F250. I removed the EGR and put a plate and gasket over the end of the EGR/carb spacer. Also removed the 1" metal tube between the exhaust manifold and EGR/carb spacer. The motor runs great. Question: to prevent icing of the carb this coming winter, which do I need to replace: 1)the 1" metal tube (exhaust to EGR/carb spacer) or 2)the flexible hose that runs from a shroud in front of the exhaust manifold to the air cleaner or 3)do I need both? Thanks for any input. PS: the motor is essentially a 78-79 set up with a 1 bbl carb.
Old Aug 30, 2000 | 12:58 AM
PAUL_2's Avatar
PAUL_2
Carb icing
The heat stove from the exhaust to the air intake Id say is the best idea . If its working as it should then icing shouldnt be a problem .
Old Aug 30, 2000 | 10:55 AM
ramato's Avatar
ramato
Carb icing
bullnose1985
16
Oct 15, 2017 03:04 PM
kramttocs
16
Aug 21, 2016 11:25 PM
KsCop
35
Aug 11, 2014 03:25 PM
oneowner83
May 2, 2014 02:16 PM
Hardtruckisthebest
Oct 19, 2013 03:02 PM
