Difficult to slow down my rig.
Old Dec 26, 2007 | 10:35 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question Difficult to slow down my rig.
Im having troubles to slow down my rig in a freeway, towing a TT about 6k, it has 2 axles but only one with electric brakes; I was thinking to add a Hydroboost brake to the truck and add a 2nd axle with electric brakes. What do you think? Thanks in advance.
Old Dec 26, 2007 | 10:44 AM
Hensley Ron's Avatar
Hensley Ron
Definately ad brakes to the remaining axle and check your current brakes. You should replace the shoes on the old brakes when you get the new ones. Get a GOOD brake controller. We sell the TruControl, which puts out more power than anything on the market and is completely automatic. Other good choices are BrakeSmart, which taps into the master cylinder. Prodigy and P3 are the standards. Acceptable but not the best out there.
The controller that's advertised on this forum is essentially the same as the Brakesmart but much less expensive. I haven't tried that one myself but have heard good things so far.
Those are the first two things you should take care of, then determine if you need anything else.
Old Dec 26, 2007 | 11:23 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Thank you Ron, Im going to do that. Which is the controller advertised on this forum? and how much is the price for the TruControl?
Old Dec 26, 2007 | 11:25 AM
Hensley Ron
I think it's call MaxBrake. It sells for $357. The TruControl sells for the same.
Old Dec 26, 2007 | 11:39 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Ok, thanks again, I read both in the internet and I think a like more the truControl.
Old Dec 26, 2007 | 02:49 PM
grafekie's Avatar
grafekie
I've been very happy with the Prodigy, $100. I'm not convinced the benefit is THAT much more for an extra $300. I tow much heavier loads and its never let me down, and has always delivered enough power to stop the load and ALWAYS had more in reserve just a lever away.
Definately consider replacing that axle with a new braking axle, and get the other brake checked out to make sure its still opperating correctly and at capacity.
Old Dec 26, 2007 | 02:54 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
grafekie thank you very much for your input, and definately Im going to start replacing that axle with a new braking axle and let see what happens, and after that I will upgrade the brake controller.
Old Dec 26, 2007 | 03:19 PM
grafekie's Avatar
grafekie
Great! Remember, the problem may be as simple as an old drum and worn pads, or shot magnets, or something along those lines. Between checking the old axle and replacing the non-braking one, you may see a world of difference!
Old Dec 26, 2007 | 03:28 PM
Hensley Ron
Definately. It's amazing what trailer manufacturers will do to cut corners. Prodigy makes a good controller, but it will max out at 18Amps. TruControl will hit 48. Overkill, yes, but no one will ever see power fade with it.
Just get those brakes installed!
Old Dec 26, 2007 | 03:33 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Thanks a lot guys, you gave me the whole idea.
Old Dec 26, 2007 | 06:00 PM
fellro86's Avatar
fellro86
Check the axle you have, it may well be a bolt on addition. If you have the flange behind the hub with 4 bolt holes, then all you need to get is the backing plates and drum/hub. The axle itself will not need replaced. All the same, I would guess the controller you have is either not adjusted up high enough, or not enough output. I have had that kind of load on trailers before and stopped fine.
Old Dec 26, 2007 | 06:10 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
fellro86 thanks for your comments, but NO, the axle doesnt have that flange with 4 bolt holes. . How can I test the output, because I think it is adjusted high enough, according with the instructions.
And what about to add a Hydroboost brake to the truck? good idea? any thougths?
Old Dec 26, 2007 | 06:21 PM
fellro86's Avatar
fellro86
It would apply more pressure to the truck's brakes, but that likely isn't the issue.
the output will vary on the manual part, as well as the automatic part. If you have the manual switch, it should start at low voltage and raise to 12 volt. The automatic part, depending on how your controller works, will vary either by the amount of time applies, or the amount of inertia when you hit the brakes, up to 12 volt.
Question: how do your brakes feel? Are they pretty stiff, or do they feel normal? If stiff and kind of hard to apply, your vacuum pump may be going out, or failed.
Old Dec 26, 2007 | 07:32 PM
elmo8641's Avatar
elmo8641
check your vacuum pump. make sure it is working properly. if there is not enough vacuum then your brakes are not getting the power they should. my dads truck had this problem.
Old Dec 26, 2007 | 07:37 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
The brakes work fine, no problem, the vacuum pump has 18 pounds, the truck alone works fine.
travlingman
6.7L Power Stroke Diesel
59
Oct 26, 2014 09:11 AM
cabloom300
Jun 17, 2014 09:14 PM
bluefin
Sep 30, 2013 04:01 PM
RÖENTGEEP
All Things Towing
30
Feb 8, 2008 09:32 PM
boomer 453
All Things Towing
Sep 28, 2006 08:40 PM
