I read somewhere that you can boost low and mid rpm torque by advancing the camshaft 2 to 4 degrees as a delayed intake opening and extended intake closing is supposed to increase low end torque. I know they have special timing gears to make these adjustments, but what if I moved one cog on my 300 I-6. There appears to be about 64 cogs on the big gear so moving one cog is nearly 6 degrees--probably way too much and the truck would crap out at 2500 rpm, right? Well anyway, I just thought I'd ask.
Honda & Toyota have had variable vavle timing for yrs on their respective 4 cyl engines , it works good when it can change depending on engine load . With your engine I would imagine it would run like a 3 legged dog . Id say freeing up the intake & exhaust flows would do more than messing with the valve timing .
You are right. Headers would be the biggest benefit. I don't want to mess with the EFI intake though as I think it was designed well for good low end torque. Possibly smoothing inside the tubes and lining up the holes at all the connections, but nothing more. And also a freer flowing plastic tube and air filter (K&N style).
I just read about a company that makes hydraulic lifters that pump up higher on high rpms for greater valve lift and then bleed down quickly for low end grunt.
You're right 6 deg is probably too much. It might run OK mechanically, but I'd bet it would confuse the PCM. 2-4 is workable with carbs, don't know about EFI, good question!
If you're talking about Rhoades lifters, the folks at Clifford don't recommeend them with stock or mild camshafts. I inquired about using a set with a 264H EFI grind and was told not to, they would drop the performance back to stock. They're really for use with camshafts that are marginally streetable to regain some drivability.
