comp check
Old Aug 28, 2001 | 07:03 AM
mask's Avatar
mask
comp check
Hi I wonder what a normal reading would be when You do a Comp check on a stock -74 460 ? I think that my readings are very low, they are fairly the same but very low 105-110 psi
If some one have mont the camshaft wrong (one cog)
would that lower the reading ? the car don´t work very well either.
ps. where did the spellcheck go? ds
Mask Sweden
Old Aug 28, 2001 | 11:48 AM
laptopgeek's Avatar
laptopgeek
comp check
Hi Mask,
My freshly built 460 has 150 pounds across the board and runs like a scalded dog....if the camshaft were off a cog, that should not interfere with the sealing of the compression chamber....if a valve was BENT keeping the valve from closing all the way; that would make the compression low!! Squirt some oil into the cylinders then run your check again....let us know if your compression then increases...
The LaptopGeek -----
1974 White F100 Custom Fleetside
460 bored .040 over & C-6 automatic 2WD
Lunati cam, L&L Headers / mounts
Holley Avenger 770CFM & Edlebrock RPM
Plush black leather 40-20-40 bench seat
38 gallon JC Whitney fuel tank
Old Aug 28, 2001 | 03:33 PM
mask's Avatar
mask
comp check
The oil in the hole din´t improve the reading and I don´t think that all valves are bent,because its no real diffrens between
them. Maybe all my valve seats are bad. I dont know
Mask
Old Aug 29, 2001 | 06:41 AM
laptopgeek's Avatar
laptopgeek
comp check
Hi Mask,
All the oil was for was to verify a ~particular~ cylinder's compression did not improve when lubed with the added oil. I would have to say you've got valve problems..possibly seat issues. If the compression improved when squirting the oil into the cylinder that would indicate you've got a blatant ring sealing problem. To tell you the truth, depending on the mileage, the compression ring (top-most ring) might have some wear on it, allowing compression to pass it - and losing the charge into the crankcase. What's the mileage on the motor, Mask?...
Old Aug 29, 2001 | 06:56 AM
mask's Avatar
mask
comp check
I have no clue about the mileage but I guess its quit much.
I´m pulling it out now to do a full renovation on it.
I guess it´s time..
Mask
Old Aug 29, 2001 | 06:58 AM
laptopgeek's Avatar
laptopgeek
comp check
Good luck with the renovation!! The 460 really makes my truck a screamer!!!! I barked the tires last night...I could have smoked the entire area if I had wanted to....but let off the gas.
Hey - I need to get to Windows XP training....catch you tommorrow....
Old Aug 29, 2001 | 11:49 AM
jeff03's Avatar
jeff03
comp check
SwedMartin
Oil & Lubrication
Aug 19, 2014 09:51 AM
MBfreak
Dec 29, 2013 08:44 PM
f100swe
Aug 21, 2008 05:35 PM
fat and low
New Member Introductions
Feb 10, 2007 03:49 PM
mask
15
Feb 13, 2001 01:27 AM
