IDM Mod
Old Dec 25, 2007 | 01:53 PM
Izzy351's Avatar
Izzy351
IDM Mod
So I was perusing the list on 7point3 now that it's back, and I read the IDM mod page here:
http://www.forgotton.net/diesel/idmmod/index.htm
Has anyone done this? I'm thinking about a couple easy ones before the pace picks back up at work. Is there any reason not to do it since I have the DP? This one and the home-made high-idle are looking pretty good:
https://www.ford-trucks.com/forums/2...-2002-psd.html
Old Dec 25, 2007 | 04:33 PM
ron's power stroke's Avatar
ron's power stroke
i dont know if the IDM mod is a good idea with the DP or not.. id have to say not..but ill bump this back to the top for ya Joe..
Old Dec 25, 2007 | 05:45 PM
Izzy351's Avatar
Izzy351
Thanks Ron. I was thinking that I could call them, but I figured someone here might know. It was worth a shot.
Old Dec 25, 2007 | 07:02 PM
rebelchevy02's Avatar
rebelchevy02
Theres a fella on PSN that does that for people with the SD 7.3s aswell, people seem to notice an increase. Im waiting on a pm in return from a reputable, and DIRECT source to possibly confirm it.
Old Dec 25, 2007 | 07:26 PM
Izzy351's Avatar
Izzy351
Cool -- lemme know what you hear. I've been soldering SMT for almost 20 years, so I don't need anyone to do it for me. I was just wondering if it was a big deal when running Jody's tunes. Maybe I should've named the thread "DP Tuner & IDM Mod". According to the linked info, the guy had some kind of chip on it (especially considering the HP & torque at the wheels). I couldn't tell which one, but I figure it would be best to ask.
Old Dec 25, 2007 | 08:06 PM
rebelchevy02
Yea Ill let you know what they found, it wouldnt hurt to see what jody has to say. I read about that a long time ago, before I ever had a chip, and I thought someone told me once the SD trucks already were higher voltage then the OBS trucks.
Old Dec 26, 2007 | 12:44 AM
John311t's Avatar
John311t
The IDM mod ups the electrical charge to the injectors, this can't be done through tuning. Its fine to do it with any chip box or whatever.
IIRC..There are 3 different IDM's that were produced for the 7.3 powerstroke, I think they were something like 100V, 110V, and 120V. 120V being the highest made and was in the later trucks. This mod is getting the voltage to 140V.
This is from Joe Servo, the originator, this is exactly what the IDM mod actually does...
Injectors are very inductive loads, similar to light bulbs. When you turn on a light bulb, it does not turn on right away. it takes time for current to flow through the bulb. Time here is in millionths of a second (us). By changing some parameters on the IDM, i turn on the injectors faster and therefore keep them on longer since the PCM does not know it has happened. With a stock IDM, the injectors take 560 us to fully turn on , with the IDM mod, injectors turn on in 440us.
Old Dec 26, 2007 | 01:10 AM
Izzy351's Avatar
Izzy351
Yeah, the site I linked to above linked to that one where I read about it further. I'll have a look and see which IDM I have and go from there. Mine is an '02, and AFAIK, they didn't change a whole lot in '03 so I have pretty much the last version of the 7.3.
Good to hear from you again -- it's been a while...
Old Dec 26, 2007 | 07:56 AM
dcara's Avatar
dcara
Just a point of clairification that I'm sure no one cares about; a light bulb is not an inductive load since the inductance of a light bulb at 60 Hz is miniscule. The bulb is a variable resistive load. The resistance of the element increases as it heats up and this is what limits the current, not the very small inductance. At significantly higher operating frequencies the bulb will be come an increasingly inductive load.
Anyway, from looking at the graphs it appears that this mod shifts the HP band down about 150 RPM and increases torque at 60mph.
Does the increased torque for roughly the same HP at 60mph equate to/result in better fuel mileage?
Old Dec 26, 2007 | 10:55 AM
sneak's Avatar
sneak
Thanks for bringing this up Izzy, ' might have to do this mod.
Old Dec 26, 2007 | 11:07 AM
Izzy351's Avatar
Izzy351
I thought about it as well. If you've ever seen a matching inductor for a VLF transmitter (usually in the 20-100 kHz range), you'd understand. There's a reason it's called a "Helix House". And they can be three stories tall. This isn't exactly what I'm talking about, but it give you the idea of the scale of coil size needed way down on those freqs:
Old Dec 26, 2007 | 11:52 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Its more of a noticeable difference on the older trucks, where the jump in voltage is twice as much than the new ones. I heard it was not good to do with the PMR's, as their enemy is advanced timing. He already advances the timing as far as safely deemed possible. Then going and opening the injectors earlier is just going to increase the timing more. If you mentioned to jody that you have the IDM mod, i'd wager he would take a few degrees timing out, therefor neutralizing any benefit from the mod. Plus more voltage- possible overloaded circuit, and more heat. May burn up a wiring harness, and in extreme situation- truck fire.
Old Dec 26, 2007 | 12:14 PM
Izzy351's Avatar
Izzy351
That's kind of what I was thinking, Kris. I think I'll leave it be for now and do the DIY high-idle & add the external fuel pressure gauge like Brandon did. Thanks for the input!!
