check engine... 2 codes
Old Dec 25, 2007 | 02:02 AM
Trav460's Avatar
Trav460
my check engine light come on. its bin coming on since i bought the truck.. i usually disconnect the battery reset the computer and it would last a couple days till it come on again. But now that i got a X3 i scanned it today.. first time i got code P0000 then tried it again after a 10 min drive and got P0004. my x3 still isnt working rite so hopfully these codes exist?? does anyone no of a web site or wut these codes mean? thanx again
Old Dec 25, 2007 | 03:45 AM
Sheryle's Avatar
Sheryle
Not sure those #s exist. Look in the tech folder.
Old Dec 25, 2007 | 09:44 AM
JMac444's Avatar
JMac444
P0000 is no code at all or no codes present. Im not sure P0004 is but i bet its something similar.
Old Dec 25, 2007 | 09:47 AM
JMac444's Avatar
JMac444
P0004 - Fuel Volume Regulator Control Circuit High
<!-- / message --><!-- sig -->
Old Dec 25, 2007 | 09:55 AM
PowerStrokeHD's Avatar
PowerStrokeHD
P0000 is a "pass" or no codes/problems found DTC, so it is odd that you would have it with the P0004.
Old Dec 25, 2007 | 10:02 AM
JMac444's Avatar
JMac444
One could be a key on engine off test, on could be a key on engine on test. Thats where you could pick up the P0004 codes, or depending on the differnt tests done you could also get that code.
Old Dec 25, 2007 | 02:08 PM
3000 FPS's Avatar
3000 FPS
I am a little confused about this code P0004. I thought the 6.0L diesel regulated fuel pressure and not fuel volume. The code P0004 is a generic code for OBD II and is not used by all manufactures. So far the only maker that I have found that uses that code is GM for their fuel systems. I could not find that code in my 2005 service documentation for the 6.0L. It does means what PowerStrokeHD has posted I am just not sure if it applies to the 6.0L. Could be your x3 is putting out a wrong or false code.
Old Dec 25, 2007 | 05:54 PM
Trav460's Avatar
Trav460
i tried with the engine running and got the same code.. to be ohnest with u guys it mite be the x3 not working rite becuase i still have a corupted stock file.. wont hear back from sct till jan 4th so ill try again then after i get my tuner fixed and see if its the same code.
