MAP sensor question
Old Dec 24, 2007 | 08:13 PM
Bluestang96's Avatar
Bluestang96
MAP sensor question
I am slowly getting my 85 F150 together but I am at a stuck spot. I have the 4.9l with a NP435. I have done a little looking around under the hood hooking up vaccum lines and computer sensors and found out that the previous owner did not hook up the MAP sensor. I have it plugged in but where do I run the vaccum line from the sensor to? Does it plug in to the carb somewhere?
Old Dec 24, 2007 | 08:19 PM
Franklin2's Avatar
Franklin2
Find a spot down low on the carb with manifold vacuum, or find a spot on the intake itself with manifold vacuum, where there is suction at all times.
4x41977
Dec 24, 2010 07:49 PM
4x41977
Jun 25, 2008 12:33 AM
FordPerf300
25
Dec 29, 2007 03:46 PM
MikeFlorida
Feb 17, 2007 07:30 PM
