I'm really impressed with what i read in here the other night about "side gapping" the spark plugs. I had never heard of it before. Well, today i took out the autolite plugs i put in last month at tune-up time and i "side gapped" them. I used my bench grinder to shave down the electrodes and a small file and wire wheel to clean the tiny burrs. After driving to work on them like that i noticed an improvement in accleration that wasn't just imaginary. Even my idle seems stronger, more steadier....no kidding! And these were 99 cent autolites that i wasn't very happy with because i had been using bosch platniums for the last 4 years. I only put the autolites in to save some money. Honestly, i was going to put new bosch's back in this weekend cuz the autolites just didn't compare, plus my mileage wasn't as good either. I had nothing to lose. Like i said, it took me 30 minutes from start to finish to pull em, grind em, and put em back in. Thumbs up...thats all i have to say. Side gap your cheap autolites and enjoy! Can't wait to see if my mileage has improved at next fill-up.
I'm running a:
81 F-150 Styleside 8'bed
4.9L 1BBL Carb
C-6 Automatic Transmission
Payload Package 6100LB GVWR
Limited Slip Rear Axle
187,000 miles all put on by me
I just got done with my truck. Side gaped the plugs. I noticed a difference in power. My truck really takes off now. The idle has been smooth before so it's the same. The acceleration is smooth and powerful. My truck sounds louder too. It's actually fun driving it around stomping on the pedal! I love that feeling of torque and power. Greg.
I bought some autolites for my 351 tonight and side gapped em and put em in there also my old plugs were showing a lean conditions so i went ahead and stripped all the vacume lines off my motor that were not needed in hopes of fixing minor vacume leaks..i left the vacume advance, the lines for the air conditioning, heater, some line to the carb that was needed,the brake booster and the transmission lines. also i removed the two charcoal canisters and all their crap with them also, after i started my truck and noticed she was idling lower so i think that fixed the vacume leaks also it runs smoother and seems to have more power..i think that must be a combination of the sidegapping and the fixed vacume leak.next on my list is to actually remove the egr valve and plate, and maybe a edelbrock 1406 carb
1985 F-150/351Ho/4wd
many mods
on a quiet night your can hear the chevys rusting away
