CD player install
Old Dec 28, 2007 | 12:02 AM
greythorn3's Avatar
greythorn3
naw that was new at walmart.com with 96 cents shipping.. i got ripped off on ebay a few times to many.
Ray
Old Jan 10, 2008 | 10:58 PM
bucks77ford's Avatar
bucks77ford
Here is what I did. Not pretty, but worked out. Haven't cut my dash yet, but that's next. I'm not looking forward to cutting my dash, but It needs to be done. I mounted a car AM/FM radio (which I made a post of), but didn't like the way the **** shafts worked out, so I decided to go this route to see what happens. Why not right?
Old Jan 10, 2008 | 11:31 PM
greythorn3's Avatar
greythorn3
looks good!! your dash is a pretty color blue
Ray
Old Jan 11, 2008 | 06:29 PM
78Ranger_GARedNeck's Avatar
78Ranger_GARedNeck
so you can put a cd player in without fab-ing new metal mounting bracket? Does anyone know of where you can find a metal mountin braket for the radio/ac? or is that only going to be found in a junk truck? My daddy wont let me do any permanant damage to my truck so ill need a different mounting bracket for cuttin.
Old Jan 11, 2008 | 06:33 PM
greythorn3's Avatar
greythorn3
get some pics with the plastic dash over it im curious how it will look with it set in that far.
ray
Old Jan 11, 2008 | 07:06 PM
STGFordCrazy04's Avatar
STGFordCrazy04
I used a piece of formica to cut a cover to fit over the stock radio hole. Works great and hides any mess ups on the stock bezel.
Ive got the template of the plate I made. Send me a fax number and Ill send it in the morning. I dont have a scanner.
Old Jan 11, 2008 | 07:13 PM
wdfp's Avatar
wdfp
I ended up doing something like bucks did after having a so called professional shop install mine(looked like he chewed my dash apart with his teeth or something, jagged edges everywhere!) But for the outside cover I had a radio plate I had bought for my 80 kenworth, it was aluminum with a wood grain covering , and I simply cut it to fit the weird shape around the radio and it turned out fairly well for me, I'll try attaching a pic so you can see what I mean. Dan[IMG][/IMG]
not sure that worked but the plate was only around 20 bucks back then then I used the little tangs on the stereo cage to hold the trim and the dash to the frame I had built
J_turtle
Oct 12, 2008 08:10 PM
berganbart
Nov 28, 2007 12:15 AM
mikedogg7
Oct 8, 2006 11:40 PM
kogler
Jun 25, 2005 06:33 PM
mbnv992
Apr 5, 2003 05:04 PM
