CD player install
Old Dec 24, 2007 | 08:56 AM
jimlj's Avatar
jimlj
CD player install
I have a Alpine XM/CD reciever that I am installing in my '79 to replace the AM/FM 8 track player that I now have. Any ideas on how to do this? How much cutting is involved in this install? What did you guys do to trim the hole you have to cut? I want it to look good when I'm done.
Old Dec 24, 2007 | 09:11 AM
77HossF250's Avatar
77HossF250
When I installed mine, I cut the mounting plate behind the dash and fabbed a new plate that just fit the CD player. It was fitted to the radio mount and I found a place to mount the support in the back. The new radio didnt match the old holes in the dash. I made an aluminum trim plate to hide the hole that was left. To mount the trim plate, I was able to drill and tap holes in the new plate and screw the trim to it.
Old Dec 24, 2007 | 10:59 AM
ranger429's Avatar
ranger429
I cut the original radio plate to fit the DIN mount. There is little to no room for error. When it came time to cut my new dash bezel I used an old one 1st and then transfered the measurements over.
Old Dec 24, 2007 | 11:50 AM
psquare7575's Avatar
psquare7575
ranger 429, I'm doing that on my truck, I have a new piece from Dennis Carpenter.
It looks like with my radio's surround, I can *just barely* center it and cover both the upper and lower chrome edging of the OEM radio hole.
Old Dec 24, 2007 | 12:18 PM
ranger429's Avatar
ranger429
Just barely is correct. Not much room for a mistake.
Old Dec 24, 2007 | 12:57 PM
psquare7575
Nothing like spending $150 or so only to cut into it with a dremel
Old Dec 27, 2007 | 01:57 AM
dakonthemountain's Avatar
dakonthemountain
I just could'nt bear to cut into my dash, so I installed my surround sound reciever below it and kept the factory AM radio in the dash. If you have to though, the idea of double measuring is a good one! After all, you can't cut it bigger! :-)
Good luck!
Dak
Old Dec 27, 2007 | 02:31 AM
greythorn3's Avatar
greythorn3
i cut the bottom of the mounting plate behind the plastic dash face, from the radio hole down and threw it away and just mounted the radio in the plastid dash face.. worked GREAT!!
Ray
Old Dec 27, 2007 | 02:31 PM
guitar_demon's Avatar
guitar_demon
Originally Posted by ranger429
unrelated question, but whats the box looking thing above the supermotors logo in the pic?
Old Dec 27, 2007 | 03:34 PM
ranger429's Avatar
ranger429
That is the factory CB mic. You can see just below the lighter where it plugs in. Here is a close up pic of one of my spare mics.
Old Dec 27, 2007 | 04:20 PM
greythorn3's Avatar
greythorn3
factory cb you lucky sob!! heres my setup with my radio it has a dvd player mp3 player and backcamera along with tv reception
Ray
Old Dec 27, 2007 | 08:33 PM
ranger429's Avatar
ranger429
Ray
Thanks, that is mic 2 of 3 that I have. I also have another complete setup, an extra NOS control module and an extra NOS cable from module to CB mic. Oh yeah, I also have an NOS CB antenna that will go on the Bronco when it is back home. I will end up putting the factory CB setup in my 250 as well.
Your install looks very good.
Old Dec 27, 2007 | 08:37 PM
greythorn3's Avatar
greythorn3
the kicker is them that radio i got that does all that stuff only cost 150 bucks new... good deal for sure!! even plays music from memory cards.. and views pictures for memory cards, where u get them cb's at i sure would like one.
Ray
Old Dec 27, 2007 | 08:52 PM
ranger429's Avatar
ranger429
I shop ebay a lot.
Old Dec 27, 2007 | 09:21 PM
samtye's Avatar
samtye
pain in the ****! it's pretty time consuming
