carb to EFI
Old Dec 24, 2007 | 07:02 AM
reg1952's Avatar
reg1952
carb to EFI
Hi everyone. My truck has a 1972 302 in it. I can get a 5.0L out off a Lincoln that is blown. I was thinking of switching intakes and makeing it injected.Does anyone know if intakes will switch. I am not worryed about having to diagnois proplems later I do it everyday at work.Thanks Merry Christmas
Old Dec 24, 2007 | 07:51 AM
Truxx1956's Avatar
Truxx1956
Talking
YES the intakes will definately interchange. I guess if you're a driveability tech, you already know all the wiring and return line stuff, but if you didn't, I just thought I'd throw that in. There are several stand alone wiring setups out there to use.
Old Dec 24, 2007 | 10:27 AM
tacson's Avatar
tacson
It will work. The son of the guy who owns Painless Wiring, Lance OVerholser put a EFI intake on a 289 engine in a 2 door 64 galaxie and drove it from Texas to Indiana.
http://www.mustangandfords.com/techa...efi/index.html
Old Dec 24, 2007 | 10:42 AM
RUSTY50F1's Avatar
RUSTY50F1
It will work. If you can get all the wiring from the Lincoln you can use it. It won't know that it's not still in the Lincoln. But will run like it is.
Old Dec 24, 2007 | 11:24 AM
havi's Avatar
havi
I'll have the Roast Duck
what year Lincoln are we talking about? do you have the whole car for parts?
Old Dec 24, 2007 | 12:34 PM
reg1952's Avatar
reg1952
Getting back to havi about the lincoln. I will have the entire car if I do this. Its a 1991.
Old Dec 24, 2007 | 01:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Unless the Linc engine is blown or needs serious work, grab the whole motor. Your '72 302 will have the wrong firing order for the EFI, so you'd have to change to a late-model cam. The '91 will be a roller cam motor, better heads for unleaded gas (probably flow, too?), and totally set up for EFI. Guess it depends if you've got a lot of $$ into the '72 motor tho.
Old Dec 24, 2007 | 03:27 PM
51dueller's Avatar
51dueller
The 91 Lincoln still uses the old 302 firing order but I doubt that the camshaft in the 1972 302 will be compatible with the speed density computer.
Old Dec 24, 2007 | 03:56 PM
tacson's Avatar
tacson
In the install on the 289 they used the stock 64' cam with a mass air. So it might work with SDensity????
Old Dec 24, 2007 | 04:03 PM
havi's Avatar
havi
I'm not so sure on the speed density. By design, the mass-air has a little more "give" in modification. I'd grab the engine harness, and the ecm for sure. If you are interested in getting rid of any brake parts I might be interested.
Old Dec 24, 2007 | 04:15 PM
Virto's Avatar
Virto
I wouldn't count on it. Those of us that use SD (pre-94) in our trucks are pretty limited in what we can have done. There are a few (pretty mild) cams we can get on the aftermarket, but honestly you'll be best served swapping the entire engine. SD can get really stubborn.
Old Dec 24, 2007 | 04:21 PM
tacson's Avatar
tacson
I checked a source SD will need a cam change.
Old Dec 24, 2007 | 06:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I thought by '91 they were mass air? (In cars, anyway, trucks may have lagged)
Also thought the timing order changed in '81? Has it changed twice?
Old Dec 24, 2007 | 10:00 PM
51dueller's Avatar
51dueller
The engine imbalance changed in 1981. As far as firing orders for 5.0L EFI engines:
1-3-7-2-6-5-4-8
86-95 Mustang (89-95 Mass Air)
91-92 Cougar / T-bird (Mass Air)
96-01 Explorer (Mass Air)
86-90 Mark VII (Speed Density)
1-5-4-2-6-3-7-8
86-91 Crown Victoria, Grand Marquis and Town Car (Speed Density)
86-90 Cougar / T-bird (Speed Density)
Old Dec 25, 2007 | 09:01 AM
redpanhead's Avatar
redpanhead
A friend of mine did an EFI to an early 302 last year. Instead of changing cams to match the EFI firing order, he repined the harness at the ECM to match the old firing order.
