edge juice w/attitude or other??
what programmer to go with already have the edge but is there something better?have had no problems and love the power but maybe something better.truck has 157,000 miles but motor was replaced at 91,000 by dealer under warranty along with egr valve.mods to truck are bully dog 4 inch exhaust (cat delete) muffler 6" tip,k&n air box setup,stock tires,stock trans replaced by dealer at 96,000.i know the early 04's had problems but this motor was done in may of 06 at 91,000.thanks for all the help if you can think of any other good mods let me know.thanks alot
rnolloth,
Ditto what riggz said. If you do a search w/ "Edge" or "tuners" you'll find enough info to read over the entire Christmas holiday, probably on into 2008! Most here on FTE will tell you to go SCT Excal (I would agree after creating many of my issues running a Diablosport Predator) as they are the "safest" and most custom tunable device for the 6.0
Edge makes OK power, its just not real good on the torque-shift tranny and yet there are some faithful users who swear by them. I'd say there are far more though that have had them and now use the SCT after some hard (expensive) lessons learned.
Amp
Amp
listen close only gonna say this once in this thread..
EDGE JUICE IS GARBAGE DONT BELIEVE THE HYPE IT DOES NOT PROGRAM YOUR TRANNY IT WILL KILL YOUR TRANNY IT IS A PIECE OF CRAP AND WILL CAUSE YOUR TRUCK TO RUN LIKE CRAP
get an SCT and you will never look back ...
AND YES I KNOW WHAT I'M TALKING ABOUT I'VE USED ALMOST EVERYTHING ON THE MARKET AND I KNOW the SCT is the best safest most powerful thing you can put on a a6.0, i dare anyone with an EDGE to race me how much money you got ??
[QUOTE=LvTitan]listen close only gonna say this once in this thread..
QUOTE]
Ill second that
QUOTE]
Ill second that
Hey LvTitan! Have you had your rig on a dyno yet? DAMN!!
04 FX4 cc - 6" lift 35x13.5x20 mudders. 6.0 built from the ground up by Matt G @ SPARTAN DIESEL TECH- SDT stage2 sticks-SDT 65mm compressor (waiting on S300)-FASS 150/180-ITP fuel kit-MBRP 4"TB-no cat-BUILT 5R110-Billet HD T/C-SCT tuned by Matt & Evan at SDT--just to name a few. other "goodies"
Originally Posted by 69cj
rnolloth,
Ditch the K&N and go back stock, you won't be sorry!!!
you will still be able to make over 500HP with a stock intake so dont be afraid to put the stocker back on.. it holds more dirt, it filters better, and it is the best intake you can use and it's FREE..
if you are willing to push the limits you can get close to 450HP with an SCT and a straight pipe. everything else stock, but you are risking head gasket problems, i was lucky and never had a problem.
i'm over 500now but i have studs and larger turbo/sticks.
you can get away with 13-1400 degrees for quite a while at a time, but the general rule is 1250 continuosly.. i've run my pyro way past 1500 many times for brief, and some not so brief runs.
