How's your tailgate shut?
Old Dec 25, 2007 | 10:43 PM
jay42782's Avatar
jay42782
1979 f250 tailgate
if i try to open mine,it will fall completly off.trying to get it back on........lol
Old Dec 25, 2007 | 10:56 PM
MBBFord's Avatar
MBBFord
I just went spray the heck out of every moving part/latch on my tailgate with WD40, and it is a lot less noisier, takes less force to move, but I still need to pull the handle to close it or slam it.
Old Dec 25, 2007 | 11:32 PM
Mil1ion's Avatar
Mil1ion
WD-40 is NOT a lubricant.,
If you want a spray lubricant use chain lube soemthing
Old Dec 25, 2007 | 11:54 PM
Mr Jimi's Avatar
Mr Jimi
Mine closes like an expensive car door, nice and gently
Whose Milton
Old Dec 26, 2007 | 06:59 PM
Pickupmanx2's Avatar
Pickupmanx2
Well, mine depends on why I am shutting it,,,, whether it is getting slammed or holding the handle and closing. But it the words of my dad " ya ain't tuning a dam* piano, shut the gate!"
But it does close nice if I hold the handle, or I can slam it, same as on my 66
Old Dec 27, 2007 | 01:22 AM
dakonthemountain's Avatar
dakonthemountain
Mine will shut without "much" slaming as long as I keep it lubed. Silly as it sounds though, I always pull the handle up so as to not wear out the metal in the latching parts any sooner than possible. Call me nuts. I love my truck!
Dak
Old Dec 27, 2007 | 08:52 PM
savage066's Avatar
savage066
mine sucks. I have to lift the handle, but even then, it seems suspect. but you know what? usually the tailgate isn't the first thing on my mind when it comes to what's wrong with the truck!
Old Dec 27, 2007 | 09:46 PM
guitar_demon's Avatar
guitar_demon
one of the hinges on mine is broke so the right side hangs lower than the left. so when i close it i have to pick it up so the left is even with the right or it doesnt stay shut
Old Dec 27, 2007 | 11:06 PM
plowpusher's Avatar
plowpusher
the newer trucks use a completly different latching system more like a car door with a striker pin they started using this style in 87 so no you will never get a 70's ford to close like an 04.
Old Dec 27, 2007 | 11:16 PM
scrapyardking's Avatar
scrapyardking
I try not to open mine because when I do I half to get a budy to push in on the bed sides while I slam it.
Old Dec 28, 2007 | 04:19 PM
tomcasino's Avatar
tomcasino
Sometimes my tailgate won't even open. If it does, I can either slam it or close it softly by pulling on the handle. It depends what type of mood I'm in. Pulling on the handle usually works best. It needs to be lubed again but it's a little chilly outside now.
Old Dec 28, 2007 | 04:22 PM
JBradley500's Avatar
JBradley500
is there anyway to keep the tailgate from sliding side-to-side? is there something to put in the slots that it hinges on or anything?
Old Dec 28, 2007 | 06:07 PM
  #28
STGFordCrazy04's Avatar
STGFordCrazy04
Jbradley,
I dont know. My tailgate doest have any side to side slop.
If it did I would probably put 1 washer in between the tailgate trunion and the bed to shim the trunion out some. If necessary you could shim both sides and could probably be shimmed out 2-3 washers per side before longer bolts would be needed but I seriously doubt its that bad.
This wouldnt by chance be an aftermarket tailgate?
Old Dec 28, 2007 | 08:30 PM
  #29
JBradley500
oh yeah its aftermarket...
Old Dec 29, 2007 | 05:56 AM
  #30
STGFordCrazy04
maybe try what I said ^^^^^^
Stevem4134
Jun 28, 2021 09:43 AM
Ford1988Trucker
Aug 2, 2010 08:25 PM
kpmalone
Apr 7, 2010 04:33 PM
IMC96
May 14, 2009 11:35 AM
webgeke
Jan 3, 2005 08:07 AM
