5spd Transmission Trouble!!
Old Jun 29, 2000 | 10:02 AM
paulg's Avatar
paulg
Old Nov 16, 2000 | 07:30 PM
gman1019's Avatar
gman1019
I own a 1994 F150 with a 4.9L inline six 4x4 with the mazda 4spd w/od. It has 80,000 miles on it and i beleive it's still the original clutch. A few days ago, i noticed that I had to push the clutch pedal futher than normal to disengage so i could shift. And this morning, it disengaded right when it was at the floor and i had to jam it in to first and had trouble all the way through every gear. I added fluid to the clutch cylinder but it did help enough so i could shift. Is the slave bearing shot or what? Has anyone else had trouble with this? Thanks you very much for your input.
Old Nov 17, 2000 | 12:06 AM
PAUL_2's Avatar
PAUL_2
If you had to add fluid then you have a leak ...Most likely at the slave valve . There is a rubber inspection cover on the trans that you can remove to have a look at the slave valve . Some slave valves last over 100K miles , some die sooner . If yours is leaking & you are having shifting problems then you are lucky , mine decided to die while I was trying to turn off a 4 lane hwy & it died right there , no warning .
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
